degrees to inches( short answer please!)
does .29 each side( .58 total tow in) = 1/8 each side ( 1/4 inch total tow in) ? the shop i go to only does tow in in degrees, i have read 10 posts on degrees to inches and it seems their is only long answers that in the end i still dont know. thank you
.29* is close to an 1/8th but is really 7/64ths or 1/64th short of 1/8th
https://robrobinette.com/ConvertToeInchesToDegrees.htm
Thanks again, now that we are useing tire diameter, when I use my street tires (285/30/20)on alignment day, the number's for 315/30/18's are wrong? If so, what degrees do I need on street tires so when Hoosiers are on I have 28 degrees each side( 56 total tow in)? Yes I'm the one that wanted short answer, sorry!
