Cheapest BB kit? CTSV?
Old 05-21-2015, 10:23 PM
  #61
NemesisC5
Support Corvetteforum!
NemesisC5's Avatar
Default C5 front caliper (left) C6 front caliper (right)
The C5 and C6 front calipers use the same diameter 40.5mm pistons. The C6 caliper is claimed to be approximately 25% more rigid than the C5 and about .16 pounds heavier due additional material across the bridge.
Regarding the rear calipers, the C6 Z51 units have smaller 42.5mm pistons vs 45mm on C6 base and C5. The caliper bodies appear the same in size and shape.
Old 05-21-2015, 11:49 PM
  #62
froggy47
froggy47's Avatar
Thanks for adding to the thread & for a better picture than what I had.
I ordered the brackets today from an online gmpartscenter.net place in AZ. to get them faster than east coast only to get an email that they had to order the brackets from gm, chit.
Now for some 13.4 rotors & done. The caliper looks beefier & I am hoping will be "just right" for what I do. Like the Goldilocks & 3 bears - just right.
Who has some good 13.4 blanks for a budget "medium brake kit"
Old 05-22-2015, 12:00 AM
  #63
froggy47
froggy47's Avatar
This is not a request for pad advice, however:
It is my understanding that c5, c5z, c6 base, c6z51, all use the same pad backing plate & thickness, yes/no?
Old 05-22-2015, 10:06 AM
  #64
Zmeister
Zmeister's Avatar
froggy, from all my reading and research over the past few months that is my understanding.
Great thread going here!! Thanks for the video as well....always love your vids!!
Old 05-22-2015, 12:19 PM
  #65
NemesisC5
NemesisC5's Avatar
These pictured below seem popular choice from what I've heard and read. The description says "directional vanes" but I'm guessing it only means they are curved in a direction since they are not available for purchase as specific left and right. From word of mouth, posts from CF members and reading these may be the value proposition most consistent with your direction of upgrade.
From KNS Brakes a sponsor on CF
Scroll down KNS page for more C6 Z51 components
** I'm not advocating KNS over TCE or any forum vendor just had the bookmarks saved when I was investigating doing the same for my car
Old 05-22-2015, 12:20 PM
  #66
NemesisC5
NemesisC5's Avatar
Yes definitely
Old 05-22-2015, 12:48 PM
  #67
froggy47
froggy47's Avatar
Yes definitely
Thanks Nemesisc5, you are adding a lot of good info to this thread.
Old 05-22-2015, 12:53 PM
  #68
froggy47
froggy47's Avatar
The more I look at these pics side by side the design and thickness is clearly more robust at both "shoulders" on the c6z51, Since my caliper spread was almost hard to measure, I feel this new design will probably take caliper spread right out of the equation, hopefully the leverage from the bigger rotor will give me more "feel" in the brakes that I'm looking for.
Old 05-22-2015, 01:34 PM
  #69
RDnomorecobra
RDnomorecobra's Avatar
Originally Posted by freaknbigpanda
I'd just like to add here that the stock Z51 rotors are NOT ok for track use. I've cracked two sets of them. Auto-X is probably fine, but if you run them on the track for extended sessions (45+ min) they will crack around the holes from heat fatigue. Blanks are probably better to be honest, I think the holes weaken the structure somehow.
Drilled? Correct, its never recommended to run drilled rotors on track.
Old 05-22-2015, 02:01 PM
  #70
NemesisC5
NemesisC5's Avatar
You're welcome froggy, looking forward to your impressions after some seat time with your new setup.
Old 05-22-2015, 04:27 PM
  #71
froggy47
froggy47's Avatar
I am planning on using my stock brake lines 60k miles & no issues, easy to change later if I choose to. I know some swear by the steel braid covered lines, I always felt it was more of a big track safety thing more than anything else. Remember this is 35% street, 65% autox, 5% hpde.
Since I'm putting together this budget brake upgrade, I really can't justify replacing them just "because".
Some of the real BBK's required AN lines - so that was another expense I chose to avoid.
Old 06-30-2015, 01:43 PM
  #72
Xian
Xian's Avatar
Any updates on the budget BBK?
Old 07-03-2015, 11:33 AM
  #73
Dirk Miller
Dirk Miller's Avatar
wanted to make sure you know about the ZO6 for sale by Larry Bittner in San Louis.
dirk
Old 07-06-2015, 02:27 PM
  #74
NemesisC5
NemesisC5's Avatar
Bumping Froggy for updates
Old 07-07-2015, 02:11 PM
  #75
froggy47
froggy47's Avatar
Hi all, was away on vac for a couple weeks.
I was looking forward to bolting all this together, but after talking with yet another very helpful high perf. shop I decided that it was not enough of a gain over the stock c5 sliders to make it worth while.
Yes it would help the caliper spread issue, but the braking power gain was in the 5% (better brake torque) according to the shop. Due mostly to moving the pad out a little on the bigger rotor, "leverage". The bigger rotors are, of course, quite a bit heavier, say 3-5 lbs depending on mfg (each).
Now this might have been enough to get thru the rest of autox season, but then again might not. So far as comp. "edge".
So I stepped back from the plan, but I do think it's could be worthwhile & a fun project. Parts are all reasonable & available but you have to source them one by one, there is no "kit".
I am focused now on getting a c6z. See sig.
Old 07-07-2015, 02:55 PM
  #76
Xian
Xian's Avatar
I'm on the other coast (Florida) but was planning on picking up the bracket/rotor parts for track use and One Lap. I didn't really plan on doing the caliper but may be interested in buying the parts off you if you aren't going to use them now. Feel free to shoot me a PM if you'd like to discuss.
Christian
Old 07-07-2015, 11:01 PM
  #77
froggy47
froggy47's Avatar
Christian
I returned them,
To Cheapest BB kit? CTSV?
Old 07-08-2015, 01:34 PM
  #78
Xian
Xian's Avatar
I returned them,
<-- now I've gotta dig through the thread for the rotors and caliper bracket part #'s.
Old 07-08-2015, 03:19 PM
  #79
froggy47
froggy47's Avatar
I did some videos on my yt channel as they came is , so they would be recent videos on the corvette playlist, that should help.
Old 07-10-2015, 04:04 PM
  #80
Uhhtaken
Uhhtaken's Avatar
Location: Jacksonville,nc and Williamsburg,va North Carolina and virginia
Subbed
Quick Reply: Cheapest BB kit? CTSV?
