Correct Understeer by Tire Pressure
Old 05-11-2015, 02:35 PM
NTMD8R
NTMD8R's Avatar
Default Correct Understeer by Tire Pressure
I have always been advised that to correct/address understeer,
we should increase front tire pressure, and decrease rear tire pressure.
For Example, running Toyo R888, I use 35 front, 31 rear.
But yesterday, I was told to do EXACTLY the opposite.
Truthfully, I did the opposite (31 front, 35 rear), and could not really tell any difference.
So last night I researched (Google)... holy crap, what a lot of "hits".
And they all are in conflict with one another.
Increase:
http://www.tirerack.com/tires/tirete....jsp?techid=58
http://www.thesmokingtire.com/2012/m...teeroversteer/
http://rennlist.com/forums/racing-an...ndersteer.html
Decrease:
http://www.execstudio.com/tech_suspe...understeer.htm
http://www.drivingfast.net/car-control/understeer.htm
So....... experts ?????
.... what are we supposed to do ??????????
Old 05-11-2015, 03:31 PM
0Luke@tirerack
Former Vendor
Luke@tirerack's Avatar
St. Jude Donor '11-'12
to reduce understeer with air pressure add to the front or reduce in the rear
Old 05-11-2015, 03:56 PM
gunluvS14
gunluvS14's Avatar
I'm going to fan the flame a little bit
Understeer during entry?
Understeering in mid corner?
Understeer during exit?
Old 05-11-2015, 05:12 PM
mountainbiker2
mountainbiker2's Avatar
I'll add some more. You can have to much or to little air pressure that will cause understeer. Some where depending on the tire, driving style, and car setup, you have a sweet spot for air pressure for maximum grip. You might still have understeer though. If so, then I would look at the rear. I personally would add lots of air in the back, until I got the desire results. When I get home, I would make a sway bar change etc.
Steve
Old 05-11-2015, 10:12 PM
FASTFATBOY
FASTFATBOY's Avatar
I know I can reduce oversteer by reducing rear tire pressure only on my Z28, done it many many times.
Seems to reduce understeer the same would apply in the front.
Reduce front, add to rear for understeer.
Understeer is less front grip than the rear, take away rear grip(more air) add front grip(less air).
Old 05-11-2015, 11:15 PM
B Stead
B Stead's Avatar
Here's a link to the Goodrich g-force tire manual:
http://www.bfgoodrichtires.com/asset..._NEW_FINAL.pdf
Old 05-12-2015, 04:44 PM
ScaryFast
ScaryFast's Avatar
Street tires or R-comp? Big difference in pressure settings.
Old 05-12-2015, 06:44 PM
blkbrd69
blkbrd69's Avatar
Think of your tires as springs or sway bars.
Old 05-13-2015, 12:34 PM
96GS#007
96GS#007's Avatar
Received 1,735 Likes on 1,046 Posts
Tire pressure changes are more about fine tuning. If you have significant understeer, you need to address it via the alignment.
Of course it really starts to get complex when you add sway bars and spring rates into the conversation!
To Correct Understeer by Tire Pressure
Quick Reply: Correct Understeer by Tire Pressure
