Tru-Cool M7B Stack plate cooler for oil cooler?
I already have this cooler, it's new from another project.
Has 1/2 pipe inlets (#10) and has a 20,500 BTU Capacity. It's also known as a "Long stacked plate cooler". Dimensions are 8x11 and it has 36 plates.
Is it sufficient to use on a C5 HPDE/Street car that only runs in the winter months?
Also, should it be mounted in front or behind the radiator?
Here is a pic
Here is a pic
I Found this, same cooler
http://www.jegs.com/i/Canton-Racing-...ductId=2074058
Canton Racing Products 23-510 - Canton Racing Oil Coolers Details
Oil Coolers
This 20,500 BTU Oil cooler measures 1.5" x 8" x 11". It features brazed aluminum construction and a high flow clog resistant design. It is suitable for both engine and transmission cooling.
Oil Coolers
JEGs has a cooler
Earl's #41900 that is identicle (same size, number of plates, etc) to the one used in the TPIS engine cooler kit. It does 32,000 btu and uses AN -10 fittings which you have to buy separately.
Works well on my track car.
