Make your own brake pad shims
I've been using an old pad as a shim for a long time. I run it to the inside next to the pistons. There's no need to grind off all the material is it's straight -- which mine are as I swap them side-to-side and front-edge to back edge. These are XP-10s.
--Dan
--Dan
It's unclear to me how a flat shim will improve a long pedal?
My Wilwood SL6R calipers cause both radial and circumferential taper. The circumferential taper can be addressed by swapping side-to-side.
For the radial taper I took a bunch of backing plates to a local machine shop and had them make me some sets of tapered shims: 0.4, 0.8 and 1.2 degrees. These compensate for the taper and they work OK. Once the 1.2 degree shims stop being effective it's time to reflatten the pads, which I do on a belt sander with a Zirconia belt.
As for "long pedal" reduced knock back was what I had in mind. But it's really just my theory at this point as I have not tried the shims yet.
I'll make the other rear today & stick them in. I really don't have any taper issue on the rears anyway, just fronts. These are to push the piston back where it started and get some "heat insulation" between rotor & caliper & not spend $$$ for ti or such.
I didn't think shims helped with knockback. But they do help with keeping the pistons clean and from letting excess heat reach the pistons/fluid when the insulation from the pad material is at a minimum.
It's an e36, not a vette.
I'm particularly sensitive to pad taper because I have no brake booster. The pedal ratio and piston sizing have been altered so I have 3x the mechanical gain of the stock system, so I have 3x less piston travel per pedal push hence I'm 3x more sensitive to taper issues.
That being said, the outboard pads do suffer pretty bad radial taper - the wear rate on the outer edge is 10% higher than the rate on the inner edge.
I once borrowed a friend's older SL6R calipers - no difference.
lots of people do this, more so with calipers that allow wider pads. not much room for it on the stock brakes. With a 20 or 25mm pad there is lots of opportunity to add more spacer to isolate heat.
I have heard it can help pedal feel, but imo its a heat issue.
--Dan
I dunno, other people don't seem to have this problem. It seems I'm special
I still have the original calipers on my C5Z (with DRM pistons, SKF Race hubs) and don't have any major issue with pad taper. But maybe I'm just slow.
