Wider Front Wheel/Tire Effects
I've been running NT-01s on stock C5 base wheels at the track (HPDE) for about 5 years. They provide fantastic grip - when the surface is dry. I have a separate set of wheels that I switch over and drive to the track, so a D.O.T.-legal tire was a necessity for me.
However, I would not recomend them for a street tire unless you only go out in warm, dry conditions. Any water on the road surface, and you're slipping - and I do mean ANY. Also, they are so sticky that they pick up rocks/pebbles on the street; my peppered rocker panels, just from driving to and from the track will attest to that.
I don't know about the C5Z, but the base C5 needs a staggered overall tire diameter (and circumference) to not cause problems with the Active Handling and Traction Controi (fronts shorter than the rears). Using the correct aspect ratio (side-wall height) will allow you to run the same wheel size on all 4 corners and still have the necessary difference in outer diameter.
I don't want to dogpile the issue but I went from street driving to hpde to roadracing. I now drive a pickup on the street. Aggressive driving has no place on public roads. I also used to ride motorcyles too fast, now I do that off-road. That being said, nt01s are great. 315 square is a great setup.
