TPMS Re-learn
TPMS Re-learn
So I got new rims and new sensors and wondering how you go about re-learning them. My car thinks all four tires are flat so currently in max speed 55 mode.
I saw a thread elsewhere where there was a tool you can buy at tire rack but doesn't look like they carry it anymore. So does that mean I have to take it to a dealer? Car is a 2006 Z51. Thanks
You need to research the type of TPMS you have,then find the tool that does a reset. When I started autocross I built two sets of tires both with TPMS and found a tool that does the reset. Now when I switch from street wheels to autocross I reset the TPMS in the car. Tool cost me somewhere between 45 and 60 bucks but I forget exactly. My car is a 2006 and both sets of sensors are stock. Good luck.
mine are GM (at least that's what I was told by the seller) so what tool do you have and where did you buy it? thanks
I set mine (2000) with just a magnet. You need to wake the sensor first by driving the car. I set mine before they were mounted in the rims and had to shake each sensor to wake it up.
If you're not swapping wheels regularly, there's really no need to own a tool. Just swing into a dealership or tire place and ask for a reset. I've done just that twice and there was no charge since it only takes a couple minutes to do.
C5s you can use a magnet but C6 needs a tool. I don't remember where I got. One but I would check Rock Auto and see if they sell one. I got one back in 2007 and it was $80 then.
Received 8,929 Likes
Check Amazon. They have a Kent Moore tool for about $80.
Bill
Bill
The tool I have is a EL-50448 from Orange Electronics is also shows the number OEC-T5. This is for my 2006 C6 Coupe. I think there is also a phone number on the back, 1888-407-8767. Hope this helps.
Mike
Told they are from the same year car.
Guess in the meantime I can do this
https://www.corvetteforum.com/forums/autocrossing-and-roadracing/3154893-active-handling-defeated.html
Charley
