PAC-1236X too much for ASA cam?
Old 05-30-2015, 01:23 PM
crimlwC6
crimlwC6's Avatar
Default PAC-1236X too much for ASA cam?
I have a set of built w/ titanium retainers and PAC-1236x springs. I was going use the heads w/ a LG GX5 camshaft,however, plans changed and now I'm going to use the ASA cam. Obviously the springs are overkill but does it cause any negative effects to use these dual springs rated for over .600 on a .525 cam?
Thanks in advance
Old 05-31-2015, 09:12 AM
427ZM
Support Corvetteforum!
427ZM's Avatar
It's way overkill, but there won't be ill effects from them I don't believe. I run PAC 1207X springs which are 2 steps down from the 1236X's and my cam lifts to .660. Good news is you'll have plenty of valve train stability.
Old 05-31-2015, 02:46 PM
crimlwC6
crimlwC6's Avatar
Thanks!
Old 06-01-2015, 12:11 AM
Supercharged111
Supercharged111's Avatar
AFAIK, the only overkill is if the spring pressures are excessive to the point it can hurt your cam or bleed down/wear the lifters.
Old 06-01-2015, 10:29 PM
NemesisC5
NemesisC5's Avatar
IMO, I would consider single conical springs from Comp if available for your application.
Old 06-01-2015, 11:11 PM
crimlwC6
crimlwC6's Avatar
Yeah the issue for me is the heads are assembled so is it worth it to disassemble to go with a beehive or other spring set.
Old 06-01-2015, 11:19 PM
crimlwC6
crimlwC6's Avatar
I replied before I watched the video. Sorry! I didn't realize conical was different from beehive. Thanks!
Old 06-02-2015, 04:05 PM
QKSLVRZ
QKSLVRZ's Avatar
They will create more drag. I can't say how much more, but it seems important to many to have just enough spring for the cam.
Old 06-03-2015, 10:42 AM
moespeeds
moespeeds's Avatar
I went through this same decision process, as I have an ASA cam and some dual springs laying around for an LS6 build I'm doing. After a little research on LS1Tech I decided to go with the proper Comp Cams 26918 springs. The heavier springs will cause drag and more valvetrain wear. Check the spring pressures, if they aren't much different, I wouldn't sweat it, but for the ASA cam you don't need much and you should always build the engine for longevity wherever possible. Just my .02
Old 06-03-2015, 10:51 AM
Supercharged111
Comp 918s aren't doing anything good for longevity either.
Old 06-03-2015, 11:09 AM
moespeeds
moespeeds's Avatar
That's because I gave him the wrong part number. Do some research, you need beehive springs for 550 lift. Unfortunately Comp Cams doesn't make it easy their website sucks.
Old 06-03-2015, 08:24 PM
NemesisC5
NemesisC5's Avatar
Conicals over beehive unless you have a free set of new beehives lying around.
Old 06-04-2015, 12:38 PM
QKSLVRZ
QKSLVRZ's Avatar
Oh, one more note, they use some amount of coil bind to reduce surging in the spring, maybe having springs that can tolerate a lot more lift would increase this surging, to various bad outcomes.
To PAC-1236X too much for ASA cam?
Quick Reply: PAC-1236X too much for ASA cam?
