HOT Tunnel
HOT Tunnel
In our race cars for lightness and fire 90% of us have taken out the cockpit tunnel insulation. Also, for ballast many have used thicker steel tunnel plates. My tunnel is so hot I can't touch the metal by my shifter. So where is the tunnel heat coming from? Is it the exhaust pipes radiating heat to the thicker steel tunnel plate radiating heat to the cockpit? Is it the torque tube getting hot and radiating heat to the cockpit?
What solutions if any are racers using or are we all just suffering in our 250*F ovens?
I put gold foil insulation inside the bottom of the tunnel to help keep exhaust heat out. Additionally, I lined the interior side of the tunnel with a thick insulated pad to isolate heat from the driver.
also, can the oem c6 z06 headers (cat section) could be header wrapped while still in car or do they have to be removed?
You can probably do the mid-pipe with it on the car, but for as easy as it is to do, I'd pop it off in order to do a cleaner job.
I put Frost King insulation on my tunnel and then laid the carpet back down on it. It should work fine for your bare tunnel as well. It helped a ton blocking heat from the exhaust and it doesn't weight much at all. You can buy it at Home Depot/Lowes.
https://www.corvetteforum.com/forums...-king-mod.html
