AP Caliper, Hardbar T1 kit, Radial bolt torque spec
Hello all, I have searched, and for some reason, I cannot find this spec.
I am looking for the torque spec for the bolt that mounts the caliper to the caliper bracket with the AP Racing T1 front brake kit, for the C5. I purchased this used, and believe it's the Hardbar kit. It's a small allen head.
Thank you in advance.
Thank you for the specs. With regards to the upright...is that also called the knuckle? The reason that I ask is that the OE value is 125 ft lbs and it's the same fastener. I just want to be sure that I have the correct fastener that you are referring to.
