EZ Up shelters? Which ones last?
Hello All,
Have been on here for several years and mostly just commented on things. Just finished a weekend at NCM with Chin and our 1 QuickShade 10X10 pop up broke it legs in what I found out is a common event in Bowling Green, the afternoon gust front that swings thru at about 40 to 60 MPH!!
We haul on an open trailer and will need to get a couple of more so there is room for the car and us. What do people on here use, not use or would NEVER use again?
Thanks in advance for the information,
I purchased a 12X12 Quick Shade pop up shelter from Wal Mart several years ago and couldn't be happier. It was 1/2 the price of an EZ Up and you can order replacement parts on line on the Quick Shade web site.
Feff
Feff
EZ-Up, QuikShade and Z-Shade are all about the same although EZ-Up has "commercial grade" units. They are more expensive but the framework appears to be much sturdier.
Were you using any sort of anchors or tie downs? I made some tube anchors using 3" PVC conduit. They are 30" long with caps cemented on at at both ends and filled with sand. Put an eye-bolt through one cap and use the Harbor Freight small ratchet straps to hang them from the framework. Bungee cords can work too.
Given that potential for the wind speed you mentioned, use one weight at each corner of the shelters but remember the weight of all the tubes will add up on the trailer.
I was there too and that same gust killed the Wal-Mart brand I had just purchased. The guys next to me had an EZ Up (he said he got it at KMart years ago) and it didn't budge. Their tents had a cross bracing at the midpoint of each span tied back to the center of the tent and mine did not.
You had the other silver C5, yes? Loved seeing the flames out the back down at the hairpin turn!
"EZ Up shelters? Which ones last?"
None of them in the wind.
I've seen hundreds of them mangled over the years, even ones that were tied down securely.
I've had to rescue other drivers awnings at night while camping in th race trailer.
I had a 10 x 20 pole awning lift my 4 foot nitrogen tank 5 feet in the air (luckily it didn't land on the valve).
The best - we had a 10 x 20 EZ Up at the race shop, it was very heavy duty...............it was also $1,500.
All the store bought ones are cheap, thin metal legs that will bend easily. No one will tell you the specs on the metal gauge of the legs (even EZ Up). As always, the more you spend, the better quality.
But, none will survive those wind gusts. When the wind picks up, take em down.
EZ Up does make steel framed ones, at least they can be welded.
The $99 ones are throwaway after the wind takes them, just part of a race budget.
You can get a pole awning that uses electrical conduit - ugly but very repairable (just buy a new piece of conduit). I have a 10 x 20 and am thinking about using it again after loosing a $99 one. A bit longer to set up but not bad.
To save towing weight, I use the 5 gal. buckets from HomeD, fill them with water at the track, use them on one side and hook the other side to the bottom of the trailer.
My EZ Up brand 10x10 has done well, but I haven't really used it much yet. I just try to take the cover down at night to prevent the wind from getting it while I'm not there.
But taking the cover off is good "peace of mind".
Be careful with tying those things down to small heavy objects. Strong wind can still pick them up sometimes and you end up with those heavy objects flying through the air. A 5 gallon fuel jug to the head will really ruin your day. Tie down to a trailer, tow vehicle, or some permanent structure if possible.
Received 8,930 Likes
I have been using a 10x10 Commercial Grade EZ Up since 1999. I got it at Sam's Club for $199 back then. It came with 3 removable side curtains that let you have just one side open. A lot of people who sell stuff at flea markets have them. It is a minimum 2 person job to put it up. Much easier if you have 3. It is a slug to lift and as I get older I like it less and less. The storage cover is 8.5 in x 8.5 in x 65 in and has wheels on one end to make it easier to move around. I haul it in my 03 Tahoe by putting the right side seat down since the unit is too long to fit in the short trunk area. If I had a Burb I could keep the 2nd row seats up.
An acquaintance had one just like it with 4 sides and he would set it up at the Glen in cold windy weather and tie it down with huge stakes pounded in the dirt. They put a carpet on the grass under it and then chairs, a portable heater and a camping cook stove in it. It would stay in place with some pretty heavy winds blowing against it. The sides kept the air from getting under the top so it didn't lift like it would have without sides.
Bill
Bill
Picked one up at Costco that has been good so far, good construction and came with side curtains.
I'd suggest staying away from the Harbor Freight one, $50 on sale is nice; but it lasted me one day with less than the 40-60 mph winds you had.
Guilty as charged😊
I have one of the "better" ones from wallmart and have had it for over 5 years .... One thing I do 100% of the time is fully secure it the legs are anchored down as well as the 4 corners being attached to non moving items. The ones I have seen damaged are from not being properly secured ... so my suggestion is by one that appears to be "stronger" or the better model and just secure it every outing ...
