Headlight delete kit
I have a 03 Z06
I am looking for a headlight delete kit.
I have taking out all of the headlight assembly, I need to re-install my headlight covers.
I am looking for brackets to install my covers.
Thanks for any help or info
Michael
Michael
Related discussion here: <https://www.corvetteforum.com/forums/autocrossing-and-roadracing-classifieds/3273171-fs-c5-headlight-delete-plates.html>
Christian
'03 C5Z
Christian
'03 C5Z
Simplest solution is make really simple brackets by bending some sheet metal or aluminum and rivet the lids on there.
That's what our new driver/mechanic just did with some sheet aluminum he had left over after his Mustang build. He used Marine 5200 Fast Cure to stick the headlight cover to the bracket. It worked nicely as he was able to move the cover to the perfect position long after the two pieces had been stuck together. It's so cold it'll take a while to cure. Preliminary pic posted in other thread.
Look at Breathless Racing. Click on this link: http://www.breathlessracing.com/
I have them on my C4 and they them for the C5. They are called LeMans Headlamps.
