Does anyone have any braking questions.
#41
Location: If you don't weigh in you don't wrestle Road America
Let me see if I understand this.
In the 01-08, there is something in the ABS box that when activated allows the rear brakes to work and if you pull the fuse it mechanically shuts off the rear brakes?
I have a 1998 and I thought that pulling the fuse simply, by default, gave you regular braking.
Am I wrong here?
Really good discussion on brakes.....
Am I wrong here?
Short answer is yes.
The 97-00 cars have an external mechanical brake bias, so you can either add a heavier spring, like the one DRM sells, or gut the block all together and add an adjustable brake bias valve like the one Wilwood sells - actually I perfer the one AP sells (I've had issues with more than one Wilwood valve in the past - but that one's $80 vs $300 with the AP)
You can pull the fuse, dial in the brake bias the way you would like and either run it that way or add the fuse again and run a more balanced system with ABS.
The issue with the 97-00 cars is that "ice mode" triggers at lower g-levels than with the later cars, the 97-00 ABS modules are also know to have internal faults and once the fault sets it's junk. So it's easier to sort out but also more likely to send you on a scary ride.
Obviously you know what I'm talking about there Jim!
I wish I knew more on how the 01-08 Delphi modules block off the rear circuits but I've never been able to find that out. All I know is that it makes the car a bear to drive, you can drive the car like that but you have to tip-toe around the track and you absolutely kill the front brakes, obviously not the best way to run fast laps.
#42
[QUOTE=96CollectorSport;1590008105]Jim,
Joel,
So......pulling the fuse on the 01-08 gives you only front brakes.
Could it be that normally there is very little rear brakes on the car and the module is just reducing the front in heavy braking? Pull the fuse and now you have full normal front braking?
Could dramatic increasing of the rear pad or rotor help?
I think I am reading that the rear should lock up if the fuse is pulled, but you have found that not to be the case. Correct?
Joel,
#43
I drove my '01 w/o the ABS fuse for 2-3 events a few years ago when the ABS module was getting repaired. It was not that difficult to drive, but I did not A/B test vs a working setup on the same day. Without ABS working, I've only locked up the fronts (once w/the fuse pulled, due to nonsense traffic on a flyer, and once when a wheel sensor went bad under threshold braking).
I think the reason for this is that the ABS module defaults to a "safe" F/R bias with a bad WSS or a pulled fuse.
#44
Robert,
What pads are you using on your car? My front vs rear pad probably last 3 to 1 and maybe even more. I recall Mikymu saying the ZR1 calipers use pads that are slightly thinner than an aftermarket BBK so he is going through a lot of pads as well. From what I understand you are somewhat limited by the pad selection with the ceramic brakes so it has been difficult to find a good pad for street and track.
On my BBK, I have been using the Endless ME20's and N05S with really good results. I can get 12 to 15 days out of my fronts and there is still some pad leftover. I don't run them down to the backing plates because I have to still drive my car home but they would probably still last another couple of days.
#45
Robert,
If adding cooling and front downforce helps out my issues, I'm certainly game to try it out. Those two elements should beneift the car in general anyhow.
Wow at your pad life! And since I know your pace that's even more impressive. One of these days I might just have to sit down and do the math. I recall you stating your brakes being at a "press and forget" state which would be nice to achieve.
Then I'm sure there will be something else to deal with
#47
Joel,
I think Ben's answer above is more accurate about the rear brake bias defaulting to more front heavy setting when the fuse is pulled, I've always looked at it as the rear brakes being "shut off" when in reality it's just a system that is already front biased becomes even more front biased.
Now it seems like there is a difference in opinion as to what happens when the fuse is pulled, I believe that the system becomes more front heavy and limits rear braking. Bill on the previous page believes that there is no rear bias at all and it will make the rear lock up first.
My experience is with Geff's ST2 car - a full aero 02Z running StopTech ST-60 front and ST-40 rear brake kits. When we would get an ABS code he felt like he had no rear brakes, lock up front tires, the back end wanted to pass the front and we would go through a set of front pads much quicker.
I can see how someone would think that the rear is locking up, especially if they trail brake, but I feel like the loose feeling under braking is because of too much front brake and not enough rear.
Bill Brinkop had his ABS go out on him at NASA Nationals a couple years ago and stated that his rear brakes locked up on him - that was probably true because he was running the stock fronts in the rear and a ST-60 kit up front. Those rear brakes were so much larger than a typical rear brake set-up that once the ABS stopped assisting he was along for the ride.
One side note, I don't think a lot of us realize how much ABS interacts with us at the track. You can learn a lot about your cars overall set-up when the ABS goes bye bye. There are so many things that contribute to how the car feels under hard braking. Alignment, ride heights, corner weights, spring rates and shock settings all have a part to play in this. That assuming that you don't have any mechanical issues like bushing deflection or play, loose/worn bearings, ball joints or tie rods. You can throw aero balance in the mix too. Everything works off one another and the ABS can mask a lot of stuff to make the car "feel" fine.
#48
Jim,
Anyone got a line pressure gauge?
#50
We have some conflicting information. I wouldn't classify a ABS failure equal with pulling a fuse. a failure could be any number of things and All we know is that the unit isn’t functioning properly. it could be the electronic bias that failed to one side. Also another thing to consider. If the unit failed maybe the engineered balance for the ST kit is a heavy front bias. Maybe when the ABS called it quits it also quit compensating for that bias. The only way to know for sure is to put a line pressure gauge on the car and test it with (and without) the abs fuse pulled.
#52
I took the bleeder out of the LR caliper and installed the gauge, turned the ignition on and pressed on the brake pedal.
I got 400 psi
Pulled the ABS fuses and pressed again:
I got 150 psi
With the ignition off:
I got 300 psi
If I pulled the connector off of a wheel speed sensor:
I got 200 psi
Now this isn't with the car running so I don't have the vacuum booster - but I think the results speak for themselves.
Please make sure to read the revised results below - See post 56
Ludeaem (12-01-2015)
#53
Here is the pressure gauge I used:
I got 600 psi
I got 150 psi
I got 300 psi
I got 600 psi
I got 150 psi
I got 300 psi
#54
I got 400 psi
I got 150 psi
I got 300 psi
I got 200 psi
I got 400 psi
I got 150 psi
I got 300 psi
I got 200 psi
#55
I got 400 psi
I got 150 psi
I got 300 psi
I got 200 psi
I got 400 psi
I got 150 psi
I got 300 psi
I got 200 psi
Damn computers
What year car did you test?
How would that apply to my 1998?
Thanks Jim M.
#56
The car is a 2002 Z06 with StopTech ST-60 front and ST-40 rear calipers.
However I would take the above numbers with a grain of salt, I was trying to push on the pedal and read the gauge at the same time - so my level of pedal pressure may not have been as even.
So I re-did the test with someone else looking at the gauge as far as pedal pressure - I pushed pretty much as hard as I could.
Here are my revised and hopefully more accurate numbers.
Key off: 1150 psi
Key on: 1300 psi
Key on fuses pulled: 1000 psi
Key on fault set: 1180 psi
So here we see it's not as drastic as first thought.
Also for fun I fired the car up to see what the readings would be with the booster and I pegged the gauge!!! Well over 1500 psi!
For reference sake I will take some readings on the front as well just to compare.
Key off: 1150 psi
Key on: 1300 psi
#58
Key off: 1150 psi
Key on: 1300 psi
Key off: 1150 psi
Key on: 1300 psi
#59
https://www.corvetteforum.com/forums...re-values.html
