Quick question re Raybestos ST 43 compounds
ST43 pads and Rotor life
I am currently running ST43's, I have 8 hrs track time at Sebring (13 GS,M6) on my Centric Cyro rotors, they are done for. Is that a decent life span? Pads have another weekend at least in them.
I currently have 21 track days (2 hours or more each day) or 42 hours on the current DBA 4000 T3 rotors on my 07z and they will probably go another day or two, so your experience does not seem typical. I was getting the same wear rate on my Mustang using the stock blank Brembo rotors, about 25 days or 50 hours. I usually replace them for heat cracking, not wear.
Anyone running ST-43s on the front and rear?
Any thoughts on doing so?
I bought some ST-43s for both axels last year and haven't needed to use them yet. Wasn't sure how it would impact the brake bias front to rear, and wasn't sure if anyone thought that has actually tried it.
I have always been concerned about running the same pads front and back as the better the tire the more the wgt transfer which mean's the rears can't handle as much brake torque as the fronts.
I had asked this on be huge brake question thread but didn't get any real suggestions.
OTOH I did learn that you have to look at the pad torque at different Temps to come up with a better idea of pad matches. Still not sure of how much hotter the fronts get than the rears so not sure of Temps either.
I concur, C5 Z06, running them front and rear. MASH the pedal at 135 and slow to 40 the car gets a wee bit squirrelly, but you you know it and expect it so it is completely manageable.
Since it doesn't look like the ST31 is for sale anymore, what are you guys running on the street? I can't seem to find an expressly compatible street pad to switch back to after the track.
Check with Tim at Porterfield Brakes. They have a street/autocross compound, the R4-S, which I believe is made by Raybestos.
