C6 GS & Z06 front calipers - check your pad locating pins!
At Road America with NASA this weekend, coming into turn 5 under heavy braking (about to turn) and I hear what sounds and feels like I went over the rumble strip on the right.
After the session, I'm checking everything out and find this. Apparently the locating pin backed out, the rim spokes hit it, and ripped it out of the caliper (the rim is damaged as well). VERY thankful this didn't cause a serious accident.
So, if checking these pins isn't on your list... you may want to add it.
I was considering a brake upgrade this winter, now maybe that is moved up to this fall, and will be checking the forum for a used rim.
Stay safe, stay vigilant with your maintenance!
Miller Time Wisconsin 🍺
Location: The only thing we have to beer is beer itself 🍺
Received 1,440 Likes
2018 C7 of Year Winner
2017 C7 of Year Finalist
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
Same thing happened to a friends GS at Daytona. Turn 5 at Road America is the last turn you want brake trouble.
Great public service anouncement.
Any ideas (beside BBK's) for a cure to this ?
How often, if any, have you taken the pins out of the caliper? Mine seem to be seized in the caliper after almost 9 years and never having been out. I always remove the caliper to change pads. Tried to get a pin out of one the the calipers last year and broke 2 torx bits before I gave up. Glad you dodged that bullet.
