Toyo R888 size for C6
Old 08-13-2015, 01:29 PM
Flying24
Flying24's Avatar
Default Toyo R888 size for C6
Looking to upgrade to R888 for my track days. Looking at the sizes available there are several combinations also I have front brake cooling hoses. I can do either 18s all round or 18/19. I appreciate any ones experience. There going to be mounted on TSW wheels with +50 front +65 rear off set.
Old 08-13-2015, 08:15 PM
96GS#007
96GS#007's Avatar
Received 1,743 Likes on 1,051 Posts
Need to know wheel width of the combos you might run
As an aside, I run the R888 on my GS in stock sizes. Nice performing tire, I'm very happy with them.
Old 08-13-2015, 09:57 PM
Flying24
Flying24's Avatar
I'm leaning towards this setup
18x9.0 / 18x10.5 TSW Interlagos +50 front +65 rear off set
Old 08-13-2015, 10:07 PM
NTMD8R
NTMD8R's Avatar
I used to run 285/30/18 and 305/30/19 on my C6.
It had LG Motorsports World challenge wheels... 18x10, 19x11.
Sorry, I don't know the offsets.
But everything cleared just fine.
The wheel weights had to be the "thin" ones to clear the front calipers.
I ran through 3 sets of these tires over 6 years, autocrossing.
Old 08-14-2015, 08:36 AM
el es tu
el es tu's Avatar
toyo r888 can be done in factory 275/35r18 325/30r19 sizing
this will fit the widebody cars and with the right wheels can fit the narrow cars as well
if you want to go even wider
335/30r18 and 345/30r19 should work with the same relative height ratio as the computer system wants. note this would be a pain in the *** to get the 335s to fit up front but the rear 345s have been done before on the widebody cars
good luck!
Old 08-14-2015, 09:53 AM
dreamscometrue
dreamscometrue's Avatar
If you plan to track it a lot and this set of wheels/tires are going to be track only I would consider going square. By using the same size & offset on all four corners you are able to rotate tires and get the most life out of them. Fronts wear out the most, drivers side more than passenger side also. I have typically got 1.5 times the life out of rears when I wasn't running a square set up. Now I rotate them after every day on track and get even wear and the most life out of my tires.
I view it as; at HPDE's I'm not trying to set a new record and would like to maximize my dollar spent on consumables.
Old 08-16-2015, 02:24 AM
Bluefire
Bluefire's Avatar
For the track, run square 18". I just went to square 18x10.5 +65 TSW Nurburgring and Toyo R888. Turn of AH/TC at the track. You'll find the turn-in's are much easier. You won't go back to staggered, I promise.
Old 08-16-2015, 01:17 PM
edge04
edge04's Avatar
what size tires?
Old 08-16-2015, 08:42 PM
Bluefire
Bluefire's Avatar
Originally Posted by edge04
what size tires?
295x30x18
Old 08-17-2015, 02:08 PM
fastgsx
Cruising
fastgsx's Avatar
Is this TSW wheel and 18" square setup appropriate for a wide body?
To Toyo R888 size for C6
Quick Reply: Toyo R888 size for C6
