18' ATC Trailer Strap Question
This is discussed all over the forum I know, but I still would like to ask the question.
I just bought an ATC open trailer today and when my C6 GS was on the trailer checking the fit, it looked like straps using the front "D" rings would end up rubbing on the front air dam. Dealer is suggesting E-track and strapping around the tires, thoughts?
I see posts about T hooks but really don't know how to translate the term "t-hook" into securing my C6 to the trailer. Anyone?
Summit has them for about $9 each . . . .
http://www.summitracing.com/search/N.../?autoview=SKU
Here is a great deal on T Hooks.
http://www.ebay.com/itm/4-NEW-G70-Wrecker-Transport-T-Hook-/271883918875?hash=item3f4d8b5e1b&vxp=mtrI just bought a set of these for an enclosed ATC. JD
4 New G70 Wrecker Transport T Hook | eBay
Your tie down straps should have a hook on the end? and that goes to the T hook and the T hook goes into the frame on the car. Usually we run the straps crossed. And No it did not mess with the Splitter. Call me if you have any questions. 772 335 8318 JD
Received 8,918 Likes
To get a better angle on the T Hooks I have a shackle attached at the end of the hook and then attach my straps to the shackle.
http://www.awdirect.com/anchor-shack...-and-hardware/
Just choose the proper shackle size that fits the T Hook and has the appropriate working load classification.
Same place sells T Hooks as well.
http://www.awdirect.com/tie-down-hoo...-and-hardware/
They have tie downs as well but you have to pick and choose from a lot of possibilities.
http://www.awdirect.com/default2.asp...s with ratchet
Bill
Bill
macscustomtiedowns.com
Another option with the E-track is a tire net that goes over the top of the tire and attaches to the E-track. You will need a little room in front of the tires on your trailer to accommodate the strap ratchet. I have been using the slings on the front for 10 years with no issues. Still using D rings for the rear with straps X ed. Macs can make custom sized for your tires.
Yes, its aluminum (enclosed), I drilled holes in the floor (between cross members) and mounted with grade 8 hardware. All E-track is not created equal, if you decide on E-track make sure you get some rated for the loads you will have. The tire net I use has an idler that goes into the E-track in front of the tire, this allows the ratchet to be flat on the floor on top of E-track for easy access. Do you have some space left in front of the tires when your car is loaded on the trailer?
Sure I have space in front of the tires. Looking at how the D rings are mounted, they are bolted through the aluminum deck and a 1/4" steel backing plate below deck. Should I do something similar with the E-Track?
I not an engineer, maybe someone with engineering back ground can chime in with some thoughts/suggestions to determine how many backing plates would be sufficent.
Ended up going with Mac's Tiedowns wheel nets up front via VersaTrack that will be welded to the floor. Through the wheels in the rear to the D rings.
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,101 Likes
In my enclosed trailer I simply lay out the straps in position with the J hooks so that after the car is winched into place I can just reach under by each wheel and install the J hook. Everything ratchets into place as quickly as working around on open trailer.
Went with Mac's Versa Tie. Just had it welded today. Need to locate the car further back, but have room for that. Just checking out the straps today.
Looks good, nice track install. Macs stuff is top shelf, your set up is very similar to mine which has given me 10 years trouble free service and still going.
Originally Posted by SouthernSon
What is the strength rating on that track engagement knuckle? It really doesn't look all that substantial.
Be very fastidious and fussy with the wheel nets. Do not attach them in the dark, double check them after driving 20-50 miles to confirm they didn't move, and measure exactly where they drape onto the tire and do not accept a variance when strapping down. My experience is that the nets stick to hot tires and then as the tires cool and contract the net moves and creates slack. On low cars with little gap between the wheel and well area, it is hard to get your hands and arms behind the wheel to confirm it is firmly wrapping the entire top portion of the tire. If you were using wheel nets on a 4x4, no big deal. Finally: attach a safety chain at the read of the car (weld a D hook to the center of the trailer and run a chain through the rear cradle with very little slack). That will be the final thing holding your car onto the trailer before it comes flying off..
Some or all of the above is based on actual real life events..
