Stainless Steel Headers Made In USA for Under $850 Shipped @ Hinson Motorsports
Old 08-26-2015, 01:40 PM
0HinsonSuperCars
Former Vendor
HinsonSuperCars's Avatar
Location: Birmingham, AL www.hinsonsupercars.com 205-909-9402
Default Stainless Steel Headers Made In USA for Under $850 Shipped @ Hinson Motorsports
HINSON Motorsports is proud to offer the only ceramic coated stainless steel header built in the America under $850.00. The HINSON Motorsports C5 header systems are proudly built in the USA from stainless steel and then ceramic coated for lower under hood temperatures. Our ceramic coated stainless steel headers use mandrel bent 1 7/8" tubing and 3/8" flanges for a precision fit and finish.
Features
Stainless Steel Construction and High Temp Ceramic Coating
Easy installation
1 7/8" Mandrel Bent Tubing for peak exhaust flow
3" Collectors
Lower under hood temperatures than non-ceramic coated headers
Slip fit collector for easy connection to a performance X-pipe
Ceramic Coated X-pipe for reduced center console temperatures
Direct fit application for all C5's- No fabrication required.
Includes
Ceramic Coated Stainless Steel Headers
Ceramic Coated Aluminized Steel Header Extensions
Ceramic Coated Aluminized Steel X-pipe
Aluminized Steel Rear Axle Back Connection Pipes
O2 Sensor Wire Extensions (x2) $50 value
Clamps
Installed prior to ceramic coating
In stock and currently being ceramic coated. Anticipated ship date of July 27 2015.
Old 08-27-2015, 10:01 AM
0HinsonSuperCars
Former Vendor
Bump.
Old 08-28-2015, 11:21 AM
0HinsonSuperCars
Former Vendor
Bump.
Old 08-31-2015, 10:10 AM
0HinsonSuperCars
Former Vendor
Ttt.
Old 09-01-2015, 11:21 AM
0HinsonSuperCars
Former Vendor
Bump.
Old 09-02-2015, 10:21 AM
0HinsonSuperCars
Former Vendor
Bump.
Old 09-03-2015, 10:31 AM
0HinsonSuperCars
Former Vendor
Ttt.
Old 09-08-2015, 01:35 PM
0HinsonSuperCars
Former Vendor
Bump.
Old 09-14-2015, 11:54 AM
0HinsonSuperCars
Former Vendor
To the top.
Old 09-15-2015, 12:04 PM
0HinsonSuperCars
Former Vendor
The latest production run on these is almost finished up. Get yours on order today to secure your set.
Old 09-16-2015, 11:12 AM
0HinsonSuperCars
Former Vendor
Pre-order today to ensure your set.
Click Here To Order Your Set Today
Old 09-17-2015, 12:21 PM
0HinsonSuperCars
Former Vendor
Bump.
Old 09-18-2015, 10:59 AM
0HinsonSuperCars
Former Vendor
To the top.
Old 09-21-2015, 11:51 AM
0HinsonSuperCars
Former Vendor
Hinson Motrosports is proud to bring the C6 and C6 Z06 Corvette market the first set of MADE IN AMERICA, stainless steel, ceramic coated 1 7/8 headers for under $830.00 shipped to the lower 48 states. The headers are all mandrel bent with 1 7/8" primary tubes, 3/8" thick flanges, and 3" collectors. Also, all of our headers and x-pipes are ceramic coated to help reduce heat under the hood and the interior of the car. Our headers slide in to place without the need to loosen the engine mounts or the front crossmember. Installation time is short and can be done easily from below the car. Fitments currently available for the C6 wet and dry sump models with off road connections only.
*Expect to see gains of 25rwhp or more from the addition of these headers with a tune.
Click Here For Prices & Purchasing
*These cars are also equipt with the NEW Hinson Motorsports short throw shifter. Email chris@hinsonmotorsports.com to be put on the contact list for availability of this great new item.
Price Includes
  • Ceramic Coated Stainless Steel Headers
  • Ceramic Coated Stainless Steel X-pipe (Select your vehicle)
  • Stainless steel rear axle back connection pipes
  • O2 Sensor Wire Extensions (x2) $50 value
  • Clamps
Old 09-24-2015, 11:37 AM
0HinsonSuperCars
Former Vendor
Should start shipping in about a week in a half from now.
Old 09-25-2015, 12:59 PM
0HinsonSuperCars
Former Vendor
If your not on the B/O list to get a set of these and want a set off of this production run you better act now. These will go fast.
Old 09-28-2015, 11:17 AM
0HinsonSuperCars
Former Vendor
X-pipes are out of the fabrication shop and moving on to ceramic coating. We plan to start filling backorders and shipping them out by the end of the week. If you have not ordered yet, get o n the list.
To Stainless Steel Headers Made In USA for Under $850 Shipped @ Hinson Motorsports
Old 09-29-2015, 10:19 AM
0HinsonSuperCars
Former Vendor
Should start shipping out any day now.
Old 10-01-2015, 11:10 AM
0HinsonSuperCars
Former Vendor
Backorders start shipping today.
Old 10-02-2015, 11:16 AM
0HinsonSuperCars
Former Vendor
A lot of you guys got tracking numbers yesterday, and we will be getting more of these out today. Thanks again for your patients.
Quick Reply: Stainless Steel Headers Made In USA for Under $850 Shipped @ Hinson Motorsports
