PTM questions
PTM questions
2014 on mag ride equipped z51.
I'm sure the software has been updated here and there. You can purchase the "rough track" update at a dealer for $325 on Z06 models.
On my stingray I put it in track mode and disable the the PTM, traction control, and stabillitrak.
It does not replace launch control, but you can use launch control with it.
PTM questions
Originally Posted by z28lt1
I believe the first usage was the 2010 ZR1.
Here is a thread from M5POST re:
http://f10.m5post.com/forums/showthr...0#post18553250
So is/was "available" on 11/12/13 if ordered/equipped.
Rough Track update sounds a little like teflon lifetime coating on the paint or maybe more like a 200/300 dollar nav map update. Watch out for that one.
PTM questions
PTM questions
Not to but I thought the whole point of these mag shocks that adjust a "insert a very large number" of times per second was to handle all those variations.
Mero programs the MR and it think it may be on the aggressive side so the new cal just dials it back a little.
"The front spring is 62% higher rate on the FE7 than the FE6.
The rear spring is 22% higher rate on the FE7 than the FE6.
The different stab bar bushing tuning helps get the car to the appropriate understeer level.
The MR shocks on the FE7 have a tighter gap which means a higher “passive” curve in addition to a more aggressive MR damping tuning."
I'm guessing that the rough track calibration only affects the active part of the MR damping curve.
I actually tried swapping the FE7 sway bar bushing on my FE6 car and was interesting but not in a good way. The car was pretty prone to snap oversteer. Just squeezing the two the FE7 rear bushings felt much harder and the fronts maybe a little softer material.
To be honest I can't say that I've noticed any real lap time difference on track between PTM Sport 1, Sport 2 and Race. If you're smooth the AH doesn't intervene but in theory the higher modes will let you put a little more power down.
I ran PTM Wet one time at VIR in the rain. I should post the PDR video if I can find it but you watch the front end of the car lift as you accelerate and drop when you shift. The PTM was also limiting power like crazy but it's not intrusive like the older systems.
Froggy, did you see the fairly detailed response in the "Ask Tadge" section on PTM?
I do still have a question, what TIRE TEMPS does PTM look for in order to "unleash" more power?
Honestly, I don't believe it does. I know of one person that theorized that to be the case based on something in a GM ad but I don't recall ever seeing anything official on that. I ran an entire weekend on wheels with no TPMS and couldn't tell a difference.
PTM questions
Originally Posted by Poor-sha
I posted this in the C7Z section a while back. Got this from the folks at GM. FE7 is the Z07 suspension and FE6 is the normal Z06.
I have a small project that I'm working on and wanted to determine all of the differences between a fe6 and fe7.
I wonder what the rough track cal on an fe6 would do.
https://www.corvetteforum.com/forums...n-package.html
PTM questions
Yes, just the bushings as the bars are the same. You also might want to look at this thread I started yesterday but so far nobody seems interested in but me
I have a hard time believing that more than the adjuster screws is any different.
I only have a 2014 Z51 with MRC, but I have changed the sway bars and wheels/tires.
I have found a few things with PTM and my car.
No matter what sub-mode I select (Wet, Sport1, Sport2, Race),
there was always some interference.
Now I am talking about autocross, but exiting a corner, when I try to get on it, there was always some "bog", even in Race mode.
So, I now disable Traction control and Active Handling, which fundamentally disables PTM, and it does what I want it to.
Which springs are different? front/rear/both? Are the FE6 and FE7 springs both different?
PTM questions
PTM questions
