C5Z06 wheel/lug nut question
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Was installing my C5Z wheels for a track weekend and had a problem getting one of the lug nuts torqued (torque wrench kept turning) on the front 17" wheel. I took the wheel off to check if the stud had stripped or yielded, but it looked okay, along with the lug nut threads. What I did see was that the wheel cup (where the lug nut nests in) had "cratered", with a slight lip where material had raised. The other four cups looked perfectly normal (torque at the time was 94#). Do I have a wheel quality/safety issue, or is this an occasional happening with aluminum wheels? I just hadn't run into this issue before on my other aluminum wheels.
Thanks for any helpful information.
Do not go on track if you can't torque a lug nut.
Pictures help.
How old are the nuts, studs?
Clean the nut and the stud with brake cleaner. Try again dry & see if it feels loose.
Next step is to find a magnifying glass and look at the ends of the lug nuts to see if there is a difference on one of them.
The only time I ever had that happen was the nut threads stripped out & it was rather obvious.
Wheels without steel inserts will have the "seat" get deformed by repeated tightening of steel nuts onto the somewhat softer metal. I have had galling & since use anti seize to prevent.
Still even if the seat is deformed you should still be able to tighten a wheel on, it's a puzzle.
Might have the issue figured out.
I took a close look at the lugnuts that came with the (used) wheels, and compared them to another couple of lugnuts I had left over from a previous car ('87 Monte Carlo SS). The present lugnuts have a maximum diameter on the tapered part of about .820". The Monte Carlo lugs (that look like my C4 car stock lugnuts except for the shine) has a diameter of about .910". The Monte Carlo lugnuts fit the C5 wheel bevels very nicely. I don't know what the lugnuts I was using were originally off of, but apparently Chevrolet/GM didn't commonize the lugnut bevel size over the years. Additionally, the lugnuts had a threaded area above the bevel (for phony lug nut attachment I assume), and I believe the threads were the cause of the aluminum displacement.
I'll scrounge up a set of replacement lugnuts, and I should be ready to use the C5 wheels again (although too late for this weekend's track days that I cancelled two days ago).
Not a great picture, but on the stud hole bevel/seat you can see a shiny part where the material was raised up in a crater wall fashion. The other four seats look somewhat normal.
I see it, but still, I cannot think that the difference between that seat & the others would be the reason for a nut to not be able to meet a torque spec.
Torque is torque unless threads are stripping out.
Keep us posted.
Never heard of wheels being sold with lugnuts, that's a new one to me.
Keep us posted.
[QUOTE=froggy47;1590472901]I see it, but still, I cannot think that the difference between that seat & the others would be the reason for a nut to not be able to meet a torque spec.
Keep us posted.
Never heard of wheels being sold with lugnuts, that's a new one to me.[/QUOTE]
They were ten year old Z06 wheels at the time, and the seller threw in the lugnuts he was using.
Keep us posted.
[QUOTE=69427;1590474548]
I have 4 sets of those, I get new lug nuts every year to 2 years. They do wear if you are swapping wheels a lot. One of the vendors has new ti nuts for about $6 each, I'm thinking of trying those just for fun.
With that wear showing on the seat, I would use anti sieze IIWM and back the tq to 90.
I think your nuts are worn & it's just hard to tell. Buy new ones & try them
Keep us posted.
Keep us posted.
