Proper tie down straps for trailering your car
I get requests for this a lot so I figured that I would post it publicly again.
If you need straps for trailering your Vette to the track, call David at Howard Hill Enterprises in Macon, Ga at 478-743-8406. I've sent many forum members to him over the years and just ordered another set today.
Just mention the corvette forum and he'll know exactly what you need. He is the manufacturer so there's no middle man to deal with. He has special pricing set up for us too.
These are 10,000lb straps that are 2" wide and 8' long with a flat snap hook on the strap and a twisty snap hook on the ratchet end. You can have David put the T-hook on the strap, but I would just buy them separately (Northern Tool etc.).
I had him make my straps to be 12 feet to start with, but they were a little too long so I had him cut them down to 8 feet which is perfect.
This setup takes removes all the guess work on how to properly strap down your ride.
Howard Hill Enterprises, Inc.
5338 Jeffersonville Rd,
Dry Branch, GA.
(478) 743-8406
Ask for David
Here are a few pictures:
Dry Branch, GA.
(478) 743-8406
Ask for David
Rookieracer (09-16-2015)
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
Same here. I have seen too many folks in the paddock that would benefit greatly with a setup like this. So many times I have seen some very flimsy methods of using wheel 'nets' or straps in the wheel.
TRAKOUT (09-17-2015)
^^ makes sense and explains the need for the long straps
I just wrap a tie down like this around the A arms
http://www.summitracing.com/parts/sum-g7965/overview/
The A-arm could snap in an accident. They were never intended to be used for strapping during transport. Maybe I worry too much...
I thought everyone tied their Corvette down using the T hooks.
Thanks for sharing the strap info. I like those clip on hooks for the D rings and the T hooks. They look pretty robust. No more fumbling with an open end hook.
My T hooks have another ring in them making the pretty easy to manipulate when attaching them under the car into the slots and hooking the straps at the same time. With these straps that will be even easier.
Mine is an enclosed 22 ft trailer and it's not as bad as you would think. With these straps with T hooks already attached onto the snap hooks it's probably simple as can be.
I happened to need some new straps so the timing couldn't be better.
You will learn how to lay them out on the floor before winching the vehicle into the trailer. After the vehicle is in position it is simply a matter of reaching under the rocker panel and installing the Jhook. As fast a process as when I had my open trailer.
that's what I was thinking. they are laid out and then drive in. I'm just picturing the wheel wells being in the way. if it does work it will be so much easier than reaching under to get that strap around the a arms. this will also save me money as I won't have to buy the trailer ramps
do you guys criss cross them or just go straight to the floor hook?
When unloading, I place car into gear since I don't have parking brake installed, THEN unfasten straps.
Criss Cross. Complete routine: back truck up onto rhino ramps to raise rear and tilt trailer to the rear, lay out straps, winch car into trailer, hook the front ones first - then the rear, unfasten winch hook.
The only difference is the 8' straps were too short for me but I think that's a function of the my trailer tie down locations.
I'm able to drive right into the trailer with no issues. Aside from that I also criss cross and put in gear and then check to make sure still in gear prior to unloading.
I already have 8 foot long straps with those ends, now just need the T hooks
Scraping the splitter.
I winch on, strap the back, snug the winch and put one diagonal strap on the front tow hook.
S.
that is going to require a visual lol. Seems like a long process just to strap a car down but I'm sure you have it down to a science.
Surprised so many of you winch the car up vs drive. That mainly due to clearance concerns or just easier when loading alone.
Better yet, place the rear (and front) T-hooks and straps in place with the car on the ground. Cross them, run them out under the back (or front) of the car, pull them slightly taught and use blue racer's tape to tape them to the rear tag or front bumper cover. You don't have to lay on a hot trailer, maneuver around trailer fenders or reach blindly under the car. Get it onto the trailer, pull the open end of the straps off, feed them into the ratchets, pull out the slack and boom...done.
S.
S.
S.
S.
Winching the car up allows you to precisely place it on the trailer. In my enclosed, I also don't have to crawl in and out of the car through the window (very few trailers have a low enough curbside door opening to allow the car door to open in the trailer, especially a Corvette).
S.
As part of my process, I set the parking brake to hold the vehicle while I set up my straps. Once I get some tension on the straps I release the parking brake and take it out of gear, and then tighten down the straps. That way the tension is completely on the frame, not pulling against the parking brake or transmission. Then I set the brake and put it in gear as a final back up in case a strap fails.
