C5 Corvette Harness / Seat Belt Bar Kit from Ridetech
Old 09-21-2015, 05:31 PM
0chase@ridetech
Former Vendor
chase@ridetech's Avatar
Default C5 Corvette Harness / Seat Belt Bar Kit from Ridetech
We now offer a Stainless Steel Harness/ Seat belt bar for you C5
Driver and Passenger kits are available!
Check them here on the Ridetech website :
http://www.ridetech.com/store/c5-cor...ar-kit-en.html
Old 09-21-2015, 08:33 PM
FASTFATBOY
FASTFATBOY's Avatar
Any installed pics?
The issues I see with most bars is they are too high in relation to shoulder belt holes in the seat.
Old 09-21-2015, 11:38 PM
firebirdfan
firebirdfan's Avatar
^2nd that.
Need to see what this looks like installed.
Old 09-22-2015, 03:25 AM
r0nd3L
r0nd3L's Avatar
Originally Posted by firebirdfan
^2nd that.
3rd.
My Brey Krause bar is offset lower from the upper seat bolt bracket holes and is perfectly level with my shoulders. If the bar was any higher, it wouldn't work well.
Old 09-23-2015, 05:29 PM
0chase@ridetech
Former Vendor
Originally Posted by FASTFATBOY
Any installed pics?
Not a great pic but it shows the location.
Old 09-23-2015, 05:42 PM
firebirdfan
Any pictures of the ends and how they attach/look? Is it attached to the seatbelt mounts?
Do you have that Kirkey bolted to it?
Old 09-23-2015, 07:28 PM
FASTFATBOY
FASTFATBOY's Avatar
How low is that Kirkey in the car?
Mine is flat on a Planted mount.
Any more pics? The bar pins in and out correct?
Old 09-24-2015, 06:11 PM
0chase@ridetech
Former Vendor
Ours is bolted to it.
We made a bracket that attaches to the seat bar using one of our clamps. The clamps are available but depending on the placement of your seat and what kind of seat you are using, you will need to fabricate your own bracket.
Old 09-24-2015, 06:14 PM
0chase@ridetech
Former Vendor
The seat is pretty low in our car. This isn't a great picture but it shows the height.
Old 09-24-2015, 06:21 PM
FASTFATBOY
FASTFATBOY's Avatar
Who's seat mount is that?
Old 09-25-2015, 09:38 AM
0Rodney@ridetech
Former Vendor
Rodney@ridetech's Avatar
We fabricated it here. It's a fairly simple mount cut out of flat plate and bent. We added the adjustment holes to accommodate different drivers, but it isn't a matter of pulling a lever. It's still pretty easy to move if we need to.
Old 09-25-2015, 09:54 AM
FASTFATBOY
FASTFATBOY's Avatar
How mine is mounted, the bottom in the back is bolted directly to the planted mount. The seat is low in the car and my Hardbar harness bar is way too high. I am looking at this kit, but you guys need some better pics of this kit installed in a car.
I sent a PM to Chase a few days ago, no response to it.
Old 09-25-2015, 12:00 PM
0chase@ridetech
Former Vendor
Sorry for any inconvenience but I don't see a PM. Can you resend it or send it directly to my email? chase@ridetech.com
We should have a full line of pics and instructions within the next couple of days.
thanks
Old 09-25-2015, 12:03 PM
el es tu
el es tu's Avatar
nice!
any full or half cages for the c6 in the works?
Old 09-28-2015, 04:06 PM
0Rodney@ridetech
Former Vendor
There isn't a real good way to take a picture showing the position of the bar. I put a few in my post to try to give you an idea. I took a few measurements while I was taking pictures. The top of the bar is 5 3/4" below the center of the seatbelt bolt. I measured right to the center of the OEM seatbelt shoulder harness mounting bolt straight down to the top of the bar. That measurement will most likely give you a better idea where it is positioned.
Old 09-28-2015, 04:28 PM
FASTFATBOY
FASTFATBOY's Avatar
What is stopping the bar from rotating on that bracket? It have a top and bottom mounting point into the B pillar?
Looks good, I am glad someone finally addressed the bar being too high.
Old 09-28-2015, 05:12 PM
0Rodney@ridetech
Former Vendor
The mounting plate extends down and is attached under the seatbelt. The upper goes around the bung for the shoulder belt is radially clamped using a machined clamping washer. I'm having trouble posting pics, I will give it a try again tomorrow.
Old 09-29-2015, 08:59 AM
0Rodney@ridetech
Former Vendor
I got the pics to upload this morning.
Old 05-02-2019, 11:15 PM
Mark Leger
Mark Leger's Avatar
Can this be retrofitted to be used on the C6 Corvettes? I wouldn't mind being a test dummy for the first bar if needed.
To C5 Corvette Harness / Seat Belt Bar Kit from Ridetech
Quick Reply: C5 Corvette Harness / Seat Belt Bar Kit from Ridetech
