Ride Hight
Ride Hight
I got a 2008 Z51 mechanically Stock apart from a Loma GT2 body kit and wide wheels.
I would like to check the car is at the correct ride hight on all corners as i adjust the stock bolts.
should I trust the adjustable bolt length or should i measure with blocks on the frame where the whishbone connects vs ground?
whats an adequate rake Front/rear?
Thank you
Thank you
