C5Z Rear Tie Rod End / Toe Link Source
What are you using for replacement rear tie rod ends / toe links for your track car?
I replaced mine in 8 months ago with GM part 88955488 and have done 11 track days, 6,000 miles, and I have some reflective tape covering the end /boot. I noticed a slight movement when putting the track tires back on last night. Then put a dial indicator on the outside of the wheel and can generate 0.065" of deflection in either direction, both sides of the car. This is with the wheel in the air. There should be no movement regardless of that condition, correct?
Thanks as always!
Tim
Thanks as always!
Tim
