xp12's ok with Xp8 rears (C7)
I have a set of Xp8's for my c7 Z51. 8's won't be enough for me for the front, I was going to do 10/8's but wondering if I can get by with 12's/8's. I will be running slicks (worn) OR r888's as backup.
I don't want to go to crazy as I need to see where the Z51 measures up to the heat and issues (I have done a good bit of prevent maintenance) I just don't want to run my michelins.. last track event an instructor corded the michelins in last session on first day. ( and I have some pirellis and R888's so I plan to use those)
On my C5Z I've run 10s with 888s and 12s with Hoosiers. I normally run 10s in back for both, but I have run 8s in back for both. Probably not the best set up, but for casual HPDE it works OK. The rears aren't doing that much braking.
I would go stronger in the back personally. With the 8's the 12's are just going to be doing that much more work.
I've run the following combos.
XP12/XP10's
XP20/XP10's
XP20's/XP12's
I would at minimum do 10's. While we think the rears aren't doing much I can't get more than 5 days at Sebring before my rear pads are down to the backing plates so they must be doing something.
XP12/XP10's
XP20/XP10's
XP20's/XP12's
Supporting Vendor
St. Jude Donor '11,'13
12 -8 combo will work not the best but you will be ok. 12- 10 combo will be a lot better.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
