C6Z Brakes, Still Good For Another HPDE?
No, the pad on the left is too thin. I'd go with another box of pads in the trunk, run it to metal (or as soon as the pedal feels at all "off") then pit on knowing you have to swap pads at the track. I would personally never do a track day without a set of backup pads in hand.
Short Answer: NO
Long Answer: It appears that's a snap shot from the front rotor. I don't begin a multi-session event with my pads lower than 6mm for the front and 4mm for the rears. (C6 GS) I bought a inexpensive digital caliper reader which has allowed me to measure and track my brake pad wear. Also remember on the Z06/GS inside pads wear slightly slower than the outside. I tend to swap pad around to extend the overall life of a set.
I use this:
Rotor look fine, stop by you local Harbor Freight like store and pick one up for roughly $10.
Link to Harbor Fright 4" Digital Caliper
Short Answer: NO
I use this:
I use this:
Thanks gonna pick one up tomorrow. Do you know what the minimum thickness is? I just don't wanna crack a rotor and kill a $300 set of pads.
Not lately. They had some bluing before from the track but a couple months of street driving "milled" them down I guess lol. My son just turned 11mo so finally after a little while I'm gonna hit the track again.
I use the Napa rotors in the link below that are the same size as stock. Min thickness is listed on the site. http://www.napaonline.com/Catalog/Ca...700_0129723844.
Generally, you will see cracks between the drilled holes and/or cracks starting to jet out to the edges of the rotor before they crack all the way through (if you track hard, cracks tend to come well before min thickness). If you can catch a finger nail on the crack or see it come within 1/4 inch of the edge of the rotor, toss it. If you plan to do significant track time, go with solid or slotted rotors. Drilled tend to crack much faster.
Agree with Truth regarding min pad thickness. Brakes are the last place where you want to take a risk. I generally swap my pads if they are more than 50% worn. Let me know if you want my take offs (I have a pile of them) .
I kept the rotors on but I put on the new pads today. They can be a pain to remove and I don't want the hassle while I'm at the track.
A quarter is 0.07". Gap between new and discard thickness on the C5 is 0.07". I'm not sure what the gap between new and discard is on C6 Z06, but I'd be surprised if it is drastically different. If you track them, I'd watch them closely and have some spares on hand. Do you have stock c5 / C6 calipers in the back, or are those C6Z calipers as well?
My recommendation is be mindful of your trap speeds on the long straights going into heavy braking zones.
For example, at VIR I can trap of roughly 140+ pretty easily on the back straight, flat out I imagine the GS is capable of low 150+. I've chosen limit my traps, brake lil' early, and not throw out the anchor. Doing so limits the amount of heat generated during the braking event and sure I sacrifice the optimal lap time but in the intermediate group I'm usually faster than about 75% of the field plus I'm having fun.
Picture of cracks to watch out for. BTW:This rotor is toast and some people would wait until the cracks have stated connecting but by then I feel it too late and dangerous. Also this rotor had began exhibiting wave pattern due to all the heat cycles. Just so you know, I'm only using this rotor to December when I get a new set of fronts.
Back Straight starts @ 1:40, Braking Zone starts @ 1:59
As you can see I life early and extend the braking zone. If I were to guess this technique is probably costing me 1 second per lap, but it adds a ton of margin just in case something goes wrong and reduces the demand on my consumables... i.e. tires, brakes, rotors, fluid.
I'm not sure what a minimum thickness should be nor do I have a recommendation. As the above people have stated I would watch for cracks more so than anything. I see you're in CA and if you're running a track like Laguna which I heard can be brutal on brakes I would be very careful.
VIR Full Course - Hot Laps
