Keeping racecar in trailer for extended period of time
So got back from the track 2 weeks ago and got lazy and decided to keep the car in the trailer. I moved the car forward so the weight wouldn't tip over the trailer, Unhooked, blocked off the trailer tires and have the trailer on the standard trailer stand on the tongue.
I'm not concerned about the car however does anyone see any issues keeping the car on the trailer for a month or so at a time from the trailer perspective?
I have a 2014 ATC all aluminum 24ft trailer.
Just wanted to see if this really isn't a good idea for the trailer suspension or tires or if it won't affect anything at all.
Thanks for any input.
4th Gear
Actually I'd be more concerned about the car. One time I took my car to a car show. It was late when I arrived so the car sat in the trailer overnight. It got cold enough to frost. The next morning I open the trailer about 10 am and the car was covered in "sweat", everything, engine, frame, diff, all of it. Evidently an uninsulated trailer heats up a lot faster than heavy chunks of metal with the sun beating down on it. This is the same reason hunters leave their rifles out on the porch rather than bringing them in the nice toasty warm cabin at night. After a month or two you might find that race car a rusty lump. The more humid the climate the worse the problem.
Would there be any advantage to getting some desiccant bags and placing them around the trailer and in the car? An uninsulated metal roof will certainly get hot quicker in direct sun but if moisture can be reduced would that work?
Would leaving the roof vent open help?
We have done this fairly regularly with our chumpcars. Depending on whats in the shop, we will just put one of the cars in the trailer and lock it up. But here in the PNW we dont get the real cold to beating sun (trailer is parked to not get direct sunlight), so the sweating issues isn't a concern.
and instead of the desiccant bags I would just buy a cheap de-humidifier and leave it plugged in.
I guess the wife's SUV will just have to spend another winter outdoors!
I do it all the time without any issues. I added a couple of vents in the roof to make sure the fuel smell can get out...
I have never had the condensation problem that was mentioned earlier. Perhaps that is because I live in Southern California where it isn't too hot, cold, or humid.
Charley
Charley
Put an old school drop light with an old school 150 watt bulb in it on the radiator or under hood where it cant melt anything.
I have done this to stop an engine from freezing, it will keep enough heat in it to keep it dry(should). Like in the old country pump house.
I have also done this to an engine with the heads off, just laid it in the lifter valley to stop the condensation/rust, it works.
Worth a shot
Worth a shot
Thanks all for the replies! I will get a dehumidifier like what el Es tu posted or maybe one bigger just in case. Trailer is in direct sun light but this time of year the sun isn't has harsh. Unfortunately I don't have a vent as the AC unit now occupies where the vent was.
Dehumidifier looks to be a good idea just to be safe.
Tire and suspension wise I have been told it shouldn't be an issue although the car is heavier than the trailer lol.
My trailer didn't come with roof vents either. Luckily they aren't difficult to install. The vents are about $35 each and all you need is a ladder, drill, jig saw, screw gun, sealant, and a bunch of screws.
Charley
