Race Numbers
Race Numbers
I want to get some numbers for my car for autocross races. Guys with vinyl numbers end up taping them down anyway, because they just won't stay on at speed. It's not a dedicated race car so I need removable, so, short of painting them on, what is best? Where can I get them?
Thx
Thx
I bought my re-usable vinyl #'s from SoloTime... they've stayed on at both autoX and DE speeds.
http://www.soloperformance.com/
Downside to them is that they get dirty and probably won't last much more than a season worth of use.
Vic'sVette (10-28-2015)
My vinyls stay on at hdpe events and have lasted for several years. I store them flat on a sheet of rigid plastic. The instructions say not to use silicone based waxes on your car otherwise they will not stay on. I use Griot's carnauba based wax which doesn't have an effect on the numbers and the numbers have stayed on over multi-day events.
HTH
HTH
I ordered 2 of the "meatball" type vinyl stickers from Track Decals. Should be here on Friday, so I'll give more feedback then. I figured one big sticker might be easier to take on/off than individual numbers. I also went with a font that I could flip upside down. (I can be 81 or 18).
I have a much better solution, do what I did and just buy a vinyl cutter and make your own! Then after the event remove and trash them, and just apply new when you need them!
:-P
I am mostly kidding, I did get a vinyl cutter, its great
http://www.uscutter.com/USCutter-MH-...n-Cut-Software
vinyl is cheap (Calendar vinyl), and its amazingly easy to use. I did all the graphics on my car, when I get tired of the "Battlevette" i wont feel bad peeling it off.
:-P
Its a fun ritual the weekend before an event.
They stay on really well. I had runs in a downpour and they stayed on fine.
The following 2 users liked this post by Dan H.:
tommyc6z06 (07-10-2022),
If you use waterand a squeegee to put them on and do like someone already mentioned and store them on a piece of acrylic they will last for years like mine have.
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
It is not so much the putting them on that I have an issue with, but removing them is a PITA! I tend to leave my vinyl numbers on all the time because the corners tear when I try to get a small section started so I can pull them off. Plus this way everyone on the street looks at me like I am crazy when sitting at a stop light.
Anyone have a good tip on removing vinyl?
:-P
:-P
THAT is friggin sweet!!! What kind of vinyl do you use? Removable?
Been using my same set of Solotime numbers on 2 different cars for 4 years, say 20 events?
They go on a freshly spray waxed door & get cleaned and spray waxed before removal. Hands clean also and put back on paper they came on.
Install and remove using a flexible blue applicator.
Still still stick well enough to stay on my car at Daytona.
Not very reusable
Yep, that was my experience also. I don't think what I got was really meant to be taken on/off. The decal stretched/tore. I was able to get two events out of them but they're now in the trash. Actually I'm glad this thread came back up because I need to order something different.
:-P
:-P
