315/30-19 Setups for C6/C7
The Pilot Sport Cup 2 is now available in the 315/30-19 tire size.
The 315/30-19 tire will be a relatively easy fitment (and mild mod) on the back of a C6 or C7 because it only requires an 11" wide wheel.
For various reasons, the most likely front tire is the 295/30-19.
Pilot Sport Cup 2
295/30-19, 26.0" diameter, calls for a 10.5" wide wheel
315/30-19, 26.5" diameter, calls for an 11" wide wheel
The rear wheel should be a 19 x 11 between 75mm and 79mm offset.
The front wheel should be a 19 x 10.5 between 56mm and 59mm offset
Pilot Sport Cup 2
