View Poll Results: Which to use:
Hardbar/Vansteel Delrin Adjusters
0
0%
Zip Corvettes Poly Adjusters
0
0%
Voters: 0. You may not vote on this poll
Vote on which spring height adjusters - I have two types
The stock ones are torn up and must be replaced:
I own new sets of both the hardbar/vansteel units as well as the zip poly pads (these are curved unlike the wcc and eibach ones)
hardbar bolts supposedly wear pockets in the aluminum arms - I purchased a roll of 20 gauge hardened stainless steel to make plates to go in the contact areas (and jb weld them in place), but Im not sure if the steel will wear out the delrin really quickly
the poly pads supposedly fall off or wear off from various brands but I havent heard anything bad about the zip ones - additionally Id bond the pads to the bolts with this stuff: http://www.westsystem.com/ss/g-flex-epoxy/
Which to go with or any other ideas with the parts I have on hand?
I have kevlar and can use that if necessary (thought about possibly covering the a arm contact patchs with a triple layer of laminated 6oz kevlar for reduced friction and wear)
thanks!
thanks!
Never heard of that before. I ran a set of those for several years on my race car and I had to replace them once because the delrin wore down.
Delrin is much softer than aluminum so I can't imagine that it would wear the way you heard.
el es tu (11-06-2015)
Maybe if they were turned down to near stock bushing height, it wouldn't be so bad...but I just don't trust that design where you have a little dome pad screwing into a bolt.
OP...I would get the Lingenfelter spring end bushing/bolts. Flat design made of delrin I believe.
