elan nasa prototype. $65k
#41
Charley
#42
i was talking to the engineers they said theoretically (in spec trim) it would be in the Mid-high 1:50's at vir. They didn't give me a guess for Road Atlanta. RA is a very heavy HP dependent track, i doubt it will set that track on fire. i think mid 1:30's could happen if it has enough down force to take turn 1 without brakes.
FWIW, the SR8 Radical RA pole lap at the Radical Cup was 1:19 and change, the SR3 was 1:23.xx. Both run Dunlop slicks.
I look forward to seeing what the NP01 will do at RA on the Toyo DOT R, if I had to take a guess, I'm gonna say 1:28-1:29. I'd be pretty impressed if it did a 1:27 or quicker.
#43
The whole thing is retarded and is nothing more than an attempt to help Elan sell their cars and a pathetic attempt by NASA to attract folks to their series by offering up a flashy mail order race car. The problem is that no one will buy these cars other than filthy rich old guys that can't drive fast anyway so we'll never really know how fast they can go.
NASA needs another spec class like we need another Muslim in the white house.
#44
#45
#46
http://www.arrs.us/
Last edited by Supercharged111; 11-25-2015 at 01:05 AM. Reason: Forgot to add link
#47
I don't really have an issue with it, however I would agree that there are a small % of grassroots racers that are arrive-drive and/or buying or having build turn key cars. Sure there are a few of them, but the majority of folks are going to buy a car, then spend the next several years developing it. Even if you spent $65k doing it, it's going to be a bit easier to swallow doing it over time vs stroking a check on the front end. That's going to limit the potential buyers. That being said, they seem to be moving a few of them, so I'm interested to see how many they move going into and through 2016.
I could never have one with the intent of running it in a spec class, I would be too obsessed with tinkering with it.
#48
Well they are a business. lol
#49
i'm 100% the same way. i think spec racing is the fastest way to spend money racing. look at spec miata. you spend 10K-7k on a 1.8l engine. i could buy a ls3 for the same money.
the running costs of this car is going to be 1/2 or the running costs of a c6z. i bet with a bump in power, a diffusor and the rear sway it will put down similar times.
For most cars, 1:30 at Road Atlanta is equal to 2:00 at VIR. So mid 1:50's at VIR is going to equal to solid mid 1:20's at RA.
#50
Originally Posted by heavychevy
Agreed. Elan sells cars and NASA tries to recruit drivers and racers. They are doing what they do. How they implement it will determine its success though. Will they have a separate group for it? That would be annoying. They seem too fast to run in Lightning and IMO too small to run against full GT race cars for safety reasons.
#51
Yeah, I would want to know what group these cars will be racing in. I assume Norcal will just pile them into the already 'slightly' crowded Group C which has the following classes: SU, ST1, ST2, ST3, GTS5, GTS4, GTS3, GTS2, GTS1, PTF, PTE, PTD, PTC, PTB, AI, AIX, USTCC, INEX, CMC, CMC2, SE46, FFR, SI, Legends, and SpecZ.
#52
That being said, the height of the NP01 is much higher, so it's easier to see. When we were camera car filming it, I noticed this.
#53
There was a West that used to run with us, that I literally could not see. It was a miracle a few times he got by me, because I was doing my own thing and could not see him until he got by.
#54
Yeah, I think the price point of this car is very good. It's not a 15 year old used street car with some "race mods". A spec class with a sealed motor eliminates most if not all the additional cost of most spec classes. The problem will be getting enough to race in your region. I think they might try to combine regions to bring enough cars together at certain events.
#55
http://www.turnology.com/features/ca...et-spec-racer/
looks like we did get some data.
2.5 max lateral G force. consistent 2g.
I think a normal ST 1-2 car is around 1.5G, sustained max 1.7g. that's on $2,000 worth of Hoosiers.
Dry weight: 1,450 lbs. (estimated)
Wheelbase: 102 inches
Length: 161 inches
Height: 43.9 inches
Width: 75.4 inches
Horsepower: 185
Torque: 145 lb-ft
Max Track Speed: 155 mph
2015 kit Price: $64,995
2015 Assembled Price: $73,495
Lightweight ready-for-paint or vinyl wrap individual composite body panels (fenders, quarters, etc.)
1018 steel-tube frame with integral roll-cage structure
ACT clutch and lightweight flywheel
AEM Infinity ECU
AiM MXL2 dash (upgradeable to MXS or MXG)
Burns Stainless exhaust header
Electron Speed body and engine wiring harnesses
Mazda 185 hp, 2.0-liter MZR four-cylinder engine, tuned and sealed by Élan Power
MCS double-adjustable shocks
Hypercoil springs
OZ series-specific 17-inch x 9-inch wheels
Pyrotect fuel cell, 11 gallon
Sadev SL75 six-speed sequential transaxle
StopTech forged calipers
LED tail/brake lights
Toyo Proxes RR 235/40/17 tires
Wilwood pedals and master cylinders
#56
We seem to get a ton of little motorcycle engined race cars in STU in the Great Lakes. There are always a couple per event, I never pay attention so I can't recite them.
There's also a DP that runs SU...you can hear me screaming "get the F&$*K out of my way" in the last race video as he blew by me at Mach 1 on the straight, got between me and the leader, then parked it in the first corner. Just amazing.
#57
We can just put those little orange flags on tall poles on them like they do with dune buggies out in the sand
#59
http://blackflag.jalopnik.com/i-drov...rea-1744264890
This article says 1:01 at Buttonwillow West Loop.
I found a 2:05 for Camaro Z28.
http://fastestlaps.com/tracks/button...loop-config-24
