Pros/Cons of using an ATI dampner
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Anthony,
what one would you recommend? i have space limitations so i cant extend anything. i want the dry sump pump to be ran off the same location as the oem ac compressor. i would also like a 10% under drive or no under dive. 25% is just too much. I tried looking at summit but that search is impossible.
Maybe I missed it but long post or short post crank? ARE makes a few different systems, one that retains an internal pressure or you can do external pressure.
Have you already bought the dry sump system?
Personally I'm partial to the Daily system. This is the "normal" three stage system we use on a lot of cars because you don't have to mess with changing the engine mounts like you do on a 4 or 5 stage kit.
Premium Supporting Vendor
jason,
You are a gentleman and a scholar thank you.
I'm looking at this pump.
http://www.drysump.com/3020pump.htm
can you verify the ATI dampener part number?
when i'm ready to buy i will call you to order.
Former Vendor
jason,
Gary has some good listings here for that pump and things to go with it: http://www.drysump.com/ls1.htm
Depends on what you are after really, both the Daily and the ARE systems have their own unique qualities.
Jason said the same thing....that is an older one and doesn't need the cog drive as it is suction only. We used a similar system on the '04 WC cars.
one thing that is on topic and hasn't been answered. is if it's ran off a serpentine do i really need a ARE dampener? i already have the slp damper, can i just use that? here is the part for reference https://www.texas-speed.com/p-1968-s...tte-wbolt.aspx
Former Vendor
i called daily, their pans won't fit on my car. is a LS1 swap miata. they do look nice and simple. i really like simple.
I haven't used that SLP unit, do you know if the A/C is underdriven or not? It doesn't appear so, if that is the case then yes you probably could, you just don't want the A/C to slow down since that is being used as your suction drive now. Personally I would still go with the ATI balancer but that's me. Longer track history of no issues, at least with our race cars.
Quote:
Originally Posted by brkntrxn View Post
I have been racing my C5Z for five years now with over 10,000 race miles on it. All with stock balancer.
My power steering rack started leaking during the East Coast Champs and my plan is to change to an ATI damper and Hinson motor and trans mounts while the power steering rack is coming down. To me, it is a "might as well" when the rack has to come out. Otherwise, I personally wouldn't mess with it until you can see a definitive issue with your OEM damper.
We can do that in 1 1/2 years. We average 1200 miles per race weekend. Just ask Latebrake...
Really? Those pans are pretty darn compact. Bill knows his stuff, if it doesn't fit, it doesn't fit (at least not without some work )
the slp isn't under driven on the AC, i talked to Garry at ARE. i need the ati pulley he recommends. i guess the AC sup is smaller on that particular ATI pulley, it allows me to spin the pump at a 1:1 ratio.
