C-3 brake pads
2021 C1 of the Year Finalist - Modified
C-3 brake pads
O-k, time for me to ask a question.
I am in the process of building a 70 BB coupe race car . Gathering up parts for it and am wondering whats a good brake pad to use. Reading about the Raybestos ST-43 and like what I see, but can't find that they make it for the car. What else would be a good choice. Any ideas? Oh yea, I have to run the stock caliper.
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
Carbotech makes a D8 style pad that works pretty well. I ran XP10/8s in the stock style but with the Wilwood D8-4 aluminum calipers.
i got some PFC's .10 compound in my dad's C3. even with stock manual brakes i can still lock the tires. part number is 0008.10
the dorman historic racers are using the pfc 01 compound on the historic c3 cars. part # 0008.01 call up KNS or vengeance racing to order.
Wasn't aware PFC made a compound that fit the D8 pad but those would obviously be a good option as well.
OP,
What tires are you planning on using?
I run and recommend Cobalt Friction XR1 pads.
https://www.cobaltfriction.com/
Please give them a call and talk with owner Andie Lynn.
Lou Gigliotti runs them, Duntov Motors runs them and I run them. I used to run PFC-01s or the later models, but the Cobalt pads last longer and do not require bed in procedures. Ask Andie..............
ALSO............."Hoosier Vintage racing tires. 27.5 x 11 in rear 26.5 x 9.5 front"
you "might" find that a "square" tire settup works better for you. Depends on HP etc..........
If you look at all the fast guys you will see they all run the split endurance caliper mounted to the rear of the F. spindle with thicker pads, aftermarket or J-56 pistons and two piece rotors, you also need air ducted to the center of the rotor and lots of it.
Thanks for the input guys ! I wish I had unlimited funds, like Duntov and the "fast" guys but I don't. I've got to build on a budget and build
SMART !
I will be running 2 piece rotors and am looking at moving the calipers to the back to get more air in.
Cobalt pads look real good but at twice the price of PFC's, do they last twice as long ?
I used to run raybestos full metallic with the inconel backing plates and could get 3 weekends out of em. Even at that after 20 laps I would loose brakes. I know, that was a looong time ago !
Tell me is there really an advantage to the dbl pins ? I have SS sleeved calipers w/J-56 pistons and insulators. I could easily machine them to the dbl pin config but wonder if it's worth the trouble.
I am building the engine now and am figuring 600 to 650hp. I don't know how to build more through that restrictive intake they have us running. Those guys must make em paper thin !! Edel perf rpm.
SMART !
0008.11.13.44 would be a excellent compound for those massive hoosier's. you have a very large tire (large rotational mass) and a small rotor. getting cooling to the brakes is going to be a necessity.
The following 2 users liked this post by johnny c:
jstewart10 (12-15-2015),
Pop Chevy (12-15-2015)
SMART !
SMART !
Duntov cars were pulled "for inspection of the manifold" at CoTA and were found to be legal.
http://www.svra.com/tech-zone/
i would run a square pad set up, that way the tq is the same f/r. it's best to add adjustable prop valve for balancing. get the wilwood one, they cost about 60 bucks.
call up Vengeance Road racing to get them. they are sight sponsors, and they order threw me. so i can verify that you'll get the right stuff. http://vengeanceracing.net/ 678 513 7105
