C5 Trackspec Hood Louver Mock-up
Old 12-15-2015, 02:28 PM
Turbo-Geist
Turbo-Geist's Avatar
2017 C5 of Year Finalist
Default C5 Trackspec Hood Louver Mock-up
I'm looking to vent some excess heat from under the hood and plan to install the Trackspec Motorsports hood louvers. Initially I requested a set of mock templates to use for layout purposes and transferred the general outline onto painted poster paper. I'm looking for feedback from a function and aesthetics standpoint. The goal is to vent heat from the radiator and also engine bay heat being generated by the exhaust manifolds/turbos. Following is a series of pictures showing different combinations of T1 and GT2 louvers.
Standard T1 Arrangement
T1 Modified with Side Vents over Manifolds
T1 Side Vents Only
T1 Center with GT2 Side Vents
GT2 Side Vents Only
Old 12-15-2015, 02:29 PM
Turbo-Geist
Are any of these placements impossible to accomplish due to hood bracing or the sheet metal louvers being unable to conform to the curvature in a certain location?
Old 12-15-2015, 02:41 PM
Olitho
Olitho's Avatar
I have the GT2 louver set-up. According to what I have seen from the wind tunnel graphics is that the lowest air pressure areas are 1/3 of the way back on the hood from the nose of the car and where the air spills over from the top to the side of the front fenders.
Below is not the best picture, but it gives you an idea. Preferably the center large louver should be further forward a bit, but radiator placement is not such that it works.
Old 12-15-2015, 02:45 PM
Olitho
Olitho's Avatar
Old 12-15-2015, 02:53 PM
Olitho
Olitho's Avatar
https://youtu.be/xuamcT7AUJI
Old 12-15-2015, 10:54 PM
Reggie Dunlop
Reggie Dunlop's Avatar
Here's mine. They work for the added cooling part, I can attest to that.
Old 12-17-2015, 08:54 AM
REKCUF
REKCUF's Avatar
2016 C5 of Year Finalist
Old 12-17-2015, 08:15 PM
95wht6spd
95wht6spd's Avatar
A guy on here did some testing for best placement not so long ago. IIRC looked closest to your first pic, but further back toward windsheild.
Old 12-17-2015, 08:34 PM
95wht6spd
95wht6spd's Avatar
The thread actually has popped back up again.
https://www.corvetteforum.com/forums...pec-vents.html
Old 12-19-2015, 08:03 PM
383's Avatar
I wish someone would make this hood for less than 4K
Old 12-21-2015, 09:11 AM
brkntrxn
brkntrxn's Avatar
This may or may not help the original poster, but post 84on this thread details where I put my louvers:
https://www.corvetteforum.com/forums...6-build-5.html
-Kevin
Old 12-21-2015, 11:34 PM
Jeredk21
Jeredk21's Avatar
I went with a combo of both sets
Old 01-03-2016, 01:40 PM
Turbo-Geist
Thanks everyone for the informative information. John sent me some templates for mock-up and I purchased the full GT1 kit via Tway Motorsports. I decided to go with the standard placement as detailed in the instructions from Trackspec. This places the vents in the zones of lowest pressure. The design and shape of these vents is excellent and really compliments the lines of the car.
I think I laid down the centerline on the afternoon of December 25th and then began and completed the install on the afternoon of December 26th and going into the early morning of the 27th. All of the work was done with the hood on the car and a sheet covering the engine compartment.
Old 01-03-2016, 01:48 PM
Turbo-Geist
Marking the center line
One last look at planned placement
All templates placed
The blue tape above the headlights served as a way to extend a straight line for additional measurement up to the bottom edge of the side vents.
Old 01-03-2016, 01:59 PM
Turbo-Geist
12 out of 16 Holes drilled
No turning back now.
Making the cuts
Rough work is done
Checking fitment of vents
Removing the tape
I went ahead and aligned and pre-drilled the top and bottom center holes in the hood for all three louvers.
Rivet work complete
Old 01-03-2016, 02:02 PM
Turbo-Geist
A couple of media shots
Underside view
Up close view of center vent
patmann90 (05-05-2017)
Old 02-09-2016, 12:42 AM
FourG63 97GST
FourG63 97GST's Avatar
nice work, noted
To C5 Trackspec Hood Louver Mock-up
Old 02-09-2016, 08:31 AM
StreetSpeed
StreetSpeed's Avatar
Did it with hood attached, eh? Ballsy! BTW what is that front license plate thing you have there? My solution is less than elegant:
Old 02-09-2016, 10:28 PM
95wht6spd
95wht6spd's Avatar
He has an aftermarket front ram air plate, they are nice, but pricey.
Here is a DIY thread to make one yourself, and looks pretty good too.
https://www.corvetteforum.com/forums...cover-mod.html
StreetSpeed (02-10-2016)
Old 02-10-2016, 07:54 AM
StreetSpeed
Thanks! Just ordered the stuff from McMaster!
Quick Reply: C5 Trackspec Hood Louver Mock-up
