Tilton/Quarter Master Button clutches - What TOB?
Guys who are running 5.5" and similar button clutches - are you running a stock hydraulic TOB or did you have to upgrade to an aftermarket racing unit? I'm not sure how the depth works out vs a stock clutch. Thinking about upgrading but want to be sure that I have all the parts on-hand if I do so that the car isn't stuck tying up a hoist waiting for parts to come in.
1.65" version. You will need to have the legs machined, QM can do this. If they do it, you will still need to verify the TOB clearance. You will also need to buy the applicable tri lite TOB adapter/mount.
You will also need to get the proper button flywheel, I think the c5 and c6 versions are different than the LS1 version, but I don't have my parts list handy.
A friend of a friend has a used QuarterMaster Pro 5.5 with a bunch of spare parts from an LS1 ASA car for cheap, that's really the only reason I was looking at the QM. I much prefer Tilton based on previous experience with QM stuff, but my purse strings are a bit tight to buy everything new
The old QM stuff was less than desirable, honestly. The new stuff is top notch. Theres no comparison to the stuff from an Old ASA car, so be a little leary.
You can call up QM and theyll source the TOB and stand you need.
Does this setup use the stock flex plate/button adapter?
Louis
Louis
Sorry, it's the ASA/LS1 flywheel, but the clutch itself is a current model QM Pro setup, so it's the latest and greatest in terms of design. It has its own button flywheel and works in conjunction with a flexplate for the ring gear.
The one I had experience with previously was an older 4.5" carbon fiber unit in a reverse mount starter setup, where the flex plate was bolted onto the face of the clutch body. It worked great until the flexplate came apart and tore up everything inside the bellhousing We replaced that one with a Tilton setup that worked beautifully.
Here's a 7.25" QM full setup for a C6Z.
https://www.corvetteforum.com/forums...-assembly.html
It's a great setup for the track but a real PITA in my driveway!
Jim
Jim
Dang, that's a good deal. I picked up the 5.5 so I'm going to see what I can find for a TOB setup, but will save your listing in case my costs add up too quickly for the TOB and possibly master setup. Thanks!
