Ultimate Front Grill Brake Cooling Duct DIY Install
Pics are self explanatory for most part.
Top bracing (solid rod that is welded) of the radiator supports were cut out and replaced with 1 inch square tubing, a lot lower on the supports, but doesn't look like that brace does anything anyway. Had to relocate the horns on the passenger side/split into and extend the wiring for the connector to the horns by about 1 foot to reroute the wires.
Z06 ducts were cut in half at the flat point where the ducts just start to curve. That piece was Flipped over 180 degrees and placed on opposite side of car. The stock pieces curve towards the outside of the car and forces a very sharp curved needed in the ducting. With this modification, the ducting remains as straight as possible will only a small 45 degree bend or less to get from the front grill opening to the Z06 ducts. The absolute straight path from the grill to the ducts goes right to the radiator supports, so that was not an option. The silicone tubing is 3" diameter. I also used the adjustable 3" sheet metal 90 degree elbows from Home Depot that is used for home heater/HVAC ducting. After I had the angles set where I wanted them, I just covered all the seams in GOOP.
I think it's 1/8" aluminum plate that I used for the "gates" I put on either side of the radiator. This segregates the air from radiator cooling and brake cooling.
For the Lampert spindle ducts, everyone complains about the opening. I used 0.025" aluminum sheet , cut a piece that's 7" x 2.5", cut off the corners, wrapped it around and shoved it in behind the duct mount, and put a rivet on each side. Now 100% of the air goes to the rotor center.
I bought the twin-pack plastic Naca inlets from Racer Parts Wholesale here:
http://www.racerpartswholesale.com/p...09/Naca_Ducts2
The plastic is somewhat flimsy, so I made a "frame" of the 1/8" aluminum plate for the around perimeter of the inlet ducts and trimmed off the unneeded plastic. I used 3/4" aluminum angle for the supports from the duct frame to the gates for support.
I used 1/4" spaced screen (I think) from Home Depot, galvanized steel. Also made a frame out of the 3/4" angle and a screen for the front grill to match the brake cooling screen.
Painted everything in gloss black spray paint.
I think this is the best perforaming/cheapest way to go for brake ducting you can make without doing everything in carbon fiber and spending a ton of money.
Feel free to ask questions. Enjoy! ( I used about 5 tubes of GOOP.)
Thats what i had before....didnt notice much. In other threads its discussed that air pressure is low and going around the fog lights. The front grill has the highest air pressure and only place on the car with perpendicular air flow.
I suppose there is something to say for the direct airflow. I'd be more inclined to simply open up the fog light holes though.
The guys from LG Motorsports also commented that the fog light location is pretty much useless, and direct airflow in the front middle of the car/next to the radiator is the way to go.
I have not been to the track yet with this setup...probably wont for about 10 years, i have young kids and dont want to risk my life on the track until they are in their mid teens...
anyway i am install my top of front fender vents soon, i will post it up in about a month. Nobody else has giant vents like i do besides the other 2 sets i sold.
Craiger77 (07-27-2019)
I like tinkering on my car. Doesnt matter if its necessary. I also have a roll bar, tow hitch for my trailer, and also putting in sound deadening and a nice stereo with 12 inch subwoofer in the trunk. Its a jack of all trades corvette and i love it.
cruise long trips with stereo while towing track supplies...then have a great time at a track day, and drive back. Its so versatile. Cant do it with any other platform looking this good !
I like tinkering on my car. Doesnt matter if its necessary. I also have a roll bar, tow hitch for my trailer, and also putting in sound deadening and a nice stereo with 12 inch subwoofer in the trunk. Its a jack off all trades corvette and i love it.
