C6 Build Project
C6 Build Project
So I don't post here much any more, we have a super secret Facebook group where like-minded racers share projects and ideas.
Corvette Forum has become too expensive to me to advertise, and also....
1. Everybody already knows everything....
2. More miss-information than accurate....
3. Massive repetition
Anyway, in case you miss them, my various DIY PDF's are still available here.
https://dl.dropboxusercontent.com/u/1634366/index.html
And finally, my current build. Base C6, purchased salvage, rebuilt the front end and installed LG Coilovers. Car is for NASA ST3/TT3, which is basically 10:1 power to weight ratio and I'm running "factory aero". This gives me an adjusted setup of 320hp and 3000lbs (with driver). I have a Dynojet in my shop now, so I've tuned 80hp out of the car, and have trimmed a lot of weight to get to roughly 2700lbs empty.
Latest project was to remove the B-pillar steel are rear glass, cutting around 50lbs out to offset the cage
Cage going in soon, just been instructing and TTing this past fall.
happy to share any photos or info if anyone is interested. I check in here occasionally, but can always be reached at y2khardtop at geemale
The following 2 users liked this post by davidfarmer:
PA_BLUE_C6 (01-07-2016),
Reggie Dunlop (01-02-2016)
The following 3 users liked this post by davidfarmer:
Good luck on your build. You're basically doing what I've always wanted to do with a base C6. A factory aero C6 Z51 could be the ST3/TT3 ringer.
Also, are you using 275 tires to get that adjusted whp?
Just read the rules and they state part must come from vehicle manufacturer and be for that specific generation so aftermarket parts like replica spoilers or vented hoods/fenders would not qualify as OEM Aero.
7.3.2.A.3
Plastic fender liners may be modified and/or removed. The front, top, and rear aspects of the fender well may have modifications to allow vent holes for aero and/or cooling purposes
Agree about hood replacement/modification for venting. I was concentrating on the "OEM" definition. But I don't see where it states you can use modify the OEM fenders (except flaring/rolling) in ST3/TT3 under OEM Aero. The fender well is mentioned for venting but not the fender itself so does this mean the OEM fender cannot be modified for venting?
Also agree about the ZR1 lip and rear spoiler being OEM Aero but I don't recall an OEM ZR1 lip designed for the base front bumper, just the GS, Z06 and ZR1 bumper. Does this means you can't use it on the base model even if you can figure out a way to make it fit?
Thanks.
Thanks.
But the rule states the fender well may be modified not the fender itself. If the intent of the rule was to allow modifying the actual fender, I'd think it would state something to the affect of "the fender and/or fender well may be modified.....". What do you think?
Also, what do you think about my question above regarding the use of the OEM ZR1 lip on a base front bumper?
Thanks.
Thanks.
Location: If you don't weigh in you don't wrestle Road America
The rules may be a little confusing because they talk about "production cars" in sections 7.3.2 A,B & C then in section 7.3.2 section D they talk about "production car aero" which is the guideline you need to follow for ST3. The reason for the language is because there is a non-production mod factor and they are laying out the guidelines for "production" vehicles.
You can vent the hood but you cannot vent the fenders - you can only vent the fenders if you take the hit for non-OEM aero.
Also you can't run the ZR1 aero bits unless it's a ZR1, it has to come with the base trim package of the vehicle. The base trim of the ZR1 has the spoilers, even the Z06 carbon can't use them because the carbon edition isn't the base trim of the Z06.
Now that being said, you may get away with running some of those things regionally because you competitors or ST director may not be Corvette experts but you will not get away with them at Nationals.
“OEM” is defined as any part that comes from the vehicle
manufacturer either as a standard feature, a factory option, or on a factory optional trim model/package of that generation of the street-legal (in the U.S.A.) version of the vehicle.
(unless specifically stated otherwise in these rules), will be assessed a Modification
Factor to the “Adjusted Weight/Power Ratio” (7.4)"
Since vented fenders are already called out as allowed, they are allowed in ST3 without modification.
Joel - that is a pretty conservative interpretation of the OEM aero rules, given the definition of "OEM" - “OEM” is defined as any part that comes from the vehicle
Given the above, it doesn't seem like a stretch to start with an '05 base model, put on a ZR1 body and aero bits, and still take the OEM aero bonus. The base trim model language is in the PT rules, but I don't see any mention of it in the ST rules (though I may be missing something).
Why is the consensus that the C6 non-aero will be an ST3 sleeper? Is the overall package superior to the C5 body?
