height adjusters moving
has anyone had this issue and is there an easy quick way to deal with this? I recently installed the vansteel/hardbar bolts and only had about 50 miles on them before the adjusters moved. Not sure if its the round design or what...
thanks!
thanks!
They were marked with a paint pen for direction and the tops of the bolts were measured down to the tops of the springs. The only reason I even checked them was because the ride height had dropped so dramatically. The worst one had moved about 1/4" upward in thread height.
Thinking of adding in jam nuts and loctite or nord locks to the underside of the springs.
It just weird that this has happened twice!
I had the same thing happen at Gingerman last year. We haven't run since then but I'm planning to run a jam nut as well in advance of a February race. Do you have enough room for a jam nut underneath? I was thinking of putting it on the top side but I can see your reasoning now with that threaded insert being on the bottom.
M14 is the thread size, I ordered some nuts the other day to install this week.
FWIW I was never that much of a "fan" for that bullet nosed pad, I like the pad the size of a silver dollar myself.
The adjusters on mine were awful to turn, lots of rust in the threads and nearly stripped the hex. I used a tap to chase them out, knowing that it would remove any kind of 'locking' thread feature but forgot to do a jam nut or any other kind of locking setup.
As for the bullet vs pad, the problem with a flat plate is that you'll rarely have full contact, it'll most often just be an edge of the plate touching the arm since there's so much angular movement between components. The rounded/bullet pad is so that there's always a single point of contact in order to ensure a linear, predictable spring rate throughout suspension travel.
I like the round design because the large flat surface seems like an issue - prior to replacing I had noticed that the oem ones had worn at an angle... If the vansteel/hardbar design could be the same shape but a bit wider, it would be perfect.
The bolts that vansteel provides (60mm long) only allowed 26.25" of front ride height and 27.5" in the rear (im going for oem FE4 ride height). This was likely because they anticipate most folks trying to lower their cars rather than keep the stock ride height, so I changed those out to some 70mm socket cap screws which worked well to get the height where it needed to be.
I just ordered the washers, jamnuts and new bolts in stainless. About 70 bucks - hopefully the weather will hold up and I can get them installed this weekend
Oh if you ever need to remove the plastic pad from the bolt after gluing it in, Ive found trying to grip the pad with a wrench and then trying to loosen was almost impossible; the easiest way was to unscrew the bolt from the spring until the pad contacts the underside of the spring and then keep unscrewing until it breaks the glue bond. Then use a needle or hook to clean out the glue before reuse. (note: this was after using gorilla glue epoxy)
50 bucks for 2 from vansteel
or if you want to get them made, theyre M14x2 thread
https://www.vansteel.com/index.cfm?f...p=1951&ID=3476
