No manufacturer make 285/295 size 200TW tires anymore?
Hello all,
I'm a bit surprised when I learned Hankook doesn't offer 285/35R18 in RS3 V2 anymore. BFG Rival ditched their 295 size ever since they started making Rival-S. And B-stone never offered size wider than 275 for 18" wheel selection.
So is 275/35R18 my only option? I'm really reluctant to run anything shorter than 25.6" OD.
I DD my 02 C5z and I'm still trying to make it work out for A-street.
any suggestion is much appreciated
And bump the front wheel up to an 18x9.5" and run the 275/35-18 Rival S in front (legal to do in A-Street).
Does this tire fit your needs? According to tire rack the overall diameter is 25.6"
Tire Race Link --> Bridgestone RE-11, 275/35R18, UTQG: 200 A A
When I get another set of wheels I plan on running these on my Grandsport.
Former Vendor
the BF Goodrich Rival is made in a 295/35-18 size .... currently out of stock but, should show up on the website in a month or so
Hello all,
That said, Andy Hollis mentioned that a 285/30/18 re71 will be available 3/1/16 that would be the tire I'd be trying out. Given that a pair of 275 re71's mounted on 10.5's are nearly as wide as 295 Rivals I wouldn't be shocked if the 285 re71's are between the 295 and the 315 rivals width wise. (purely speculation on my part)
for posterity
Pair of 275 re71's mounted on 10.5 wheels and pair of 295 rival non S mounted on 10.5 wheels:
and said 275's on my car:
thanks for all of the input guys. I probably will pick up a pair 18x9.5 from base C5 and put them to the front. 275/35R18 might be my best choice right now
Is it still rumored that 285/30/18 Re-71s are coming out 3/1/16? Those are going to fly off the shelves.
From some of my back to back testing I've done I would not be the least bit surprised if the 275 re71 is every bit as fast as the 315 rival or at least very close to the point that it would come down which tire you preferred the "feel" of (for me its the re71)
for posterity
for posterity
There would be some ABS worries with shorter rears. In this case I assumed for track use that you'd run a 285 square tire combo just like running the 275 square combo.
I haven't experienced it myself as I always run square or larger rear than front. So you'll have to do some more searching on the forums to find more specifics but that's what I recall off the top of my head.
