IMSA: Rolex 24 Balance of Performance tables released
Old 01-21-2016, 12:18 PM
cor123
cor123's Avatar
Default IMSA: Rolex 24 Balance of Performance tables released
Thursday, 21 January 2016
Marshall Pruett
............In GT Le Mans, no weight changes were made, and only one air restrictor change has been implemented. Corvette Racing's C7.Rs have smaller holes to feed air to its V8 engines, and lost a total of 0.4 mm from the twin restrictors, which now have 29.9 mm openings to breathe through.
Turbocharged GTLM cars from BMW (sweeping boost reductions), Ferrari (sweeping boost reductions), and Ford (sweeping boost reductions) have had adjustments, except for peak RPM boost.
Fuel tank capacities and fuel flow restrictors for all five GTLM manufacturers have been set by IMSA for its big season-opening race. BMW's M6 (+9 liters to 104L, 33.5 mm), Corvette's C7.R (+6 liters to 92L, 32.0 mm), Ferrari's 488 (78L, 29.5 mm), Ford's GT (+3 liters to 98L, 35.0 mm), and Porsche's 911 RSR (+6 liters to 91L, 32.0 mm) represent the anticipated consumption and flow rates required to keep the cars on equal footing. BMW had the rear wing Gurney flap height increase (+10 mm to 15 mm total).............
More here:
http://www.racer.com/imsa/item/12536...eleased_125369
IMSA Makes Significant BoP Changes for Rolex 24
By John Dagys
...........GT Le Mans:
***BMW M6 GTLM: Reduction in boost ratios, larger Gurney (5 to 15mm), larger fuel capacity (95 to 104 liters) and 33.5mm refueling restrictor
***Corvette C7.R: 0.2 mm smaller air restrictor (30.1 to 29.9mm), 6 liter increase in fuel capacity (86 to 92 liters) and 32mm refueling restrictor
***Ferrari 488 GTE: Slight reduction in boost ratios, confirmed 78 liters fuel capacity and 29.5mm refueling restrictor
***Ford GT: Reduction in boost ratios, 3 liter increase in fuel capacity (95 to 98 liters), 35mm refueling restrictor
***Porsche 911 RSR: 6 liter increase in fuel capacity (85 to 91 liters), 32mm refueling restrictor
More here:
http://sportscar365.com/imsa/iwsc/im...-rolex-24-bop/
Old 01-22-2016, 03:40 PM
Moto One
Moto One's Avatar
You know I'm sorry, but I wish they (race org's) would just go back to run what you (manufacture) built... This is endurance racing. It's just getting way to PC. Next they will make a rule that all drivers have to be the same size/weight and all be right handed....
Mark
Old 01-22-2016, 08:57 PM
raff
raff's Avatar
St. Jude Donor '15-'16-'17-‘18-'19-'20-'21-'22
From IMSA Rolex 24 Balance of Performance tables:
scroll to pg 4 for GTLM specs.
http://www.imsa.com/sites/default/fi...Perform....pdf
Old 01-26-2016, 04:57 PM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
for Christ sake....
To IMSA: Rolex 24 Balance of Performance tables released
Quick Reply: IMSA: Rolex 24 Balance of Performance tables released
