-C5R 'Box car' #14 Updates at LG Motorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Hi all,
This is a car that has been through our shop a number of times for various upgrades over the years and has been a very awesome project every time it arrives.
A brief history
#14 is one of the 20 "box" Corvette's that GM did for the SCCA racers in '99 and '00. When we first saw the car back in 2007 it had a stock LS6, roll cage, CCW wheels, and a fuel cell.
In 2008 we installed a LS2 based 402, LG 1 3/4 Super Pro's, G2 coil overs, and our diff/trans cooler. Over the years since then we have added our mono ball control arms, PFC brakes and normal track maintenance items.
Last year the car grew tired and needed a 'refresh'.
This was the car circa 2010.
The engine needed to come out, so a 427 was planned this go around as well as a proper oil system rather than the accusump/wet system it had before. New radiator, and AIM data and dash system as well.
Ground work was a ERL 427 sleeved block with bronze lifter bushings
Keeping the 427 breathing was a set of our LS7 fully ported heads with one piece Ti valves, stainless exhaust, CNC ported chambers and ports.
Making sure that the new engine has plenty of oil, a 3 stage Daily Dry Sump is being used.
Billet Daily pan
3 stage Daily pump
Daily Pan assembled with pump
Pan going on
Cooling the new power plant is a custom radiator with engine oil cooler and PS cooler built in.
To feed the Daily pump we used a drop in ARE C6Z oil tank located in the stock C6Z location
ARE tank
Fender removed
Oil tank installed
Exhaust was upgraded to new LG Super Pro 1 7/8 headers with X and custom side 3" exits
LG Super Pro 1 7/8
Custom side exit
3" all the way
Wiring for the engine was upgraded to a new harness as well as a later model GM PCM
All (new) hoses and fluid lines built in-house using BMRS hose and fittings, covered in protective heat wrap
Specs
1999 #14 Corvette "box" car
Engine
Trans/Diff/Driveline
Suspension
Aero
Wheels/Tires
Brakes
Power output varies on event the car is running and rules it has to meet.
Feel free to shoot me any questions about this car or a similar package for your own car.
#14 at MSR 1-15-16
A brief history
Billet Daily pan
3 stage Daily pump
Pan going on
ARE tank
Fender removed
Oil tank installed
LG Super Pro 1 7/8
Custom side exit
3" all the way
Specs
Engine
- ERL sleeved 427 short block with forged internals
- LG G7X4RR camshaft
- Comp short travel link bar lifters
- C5R single row timing chain
- LG Motorsports LS7 heads with one piece Ti intake/SS exhaust valves
- FAST 102 intake
- NW 102mm TB
- ATI balancer
- Daily 3 stage dry sump oil system
- LG Motorsports 1 7/8 Super Pro Headers
- GM 3.42 diff
- GM C5 T56
- LG Motorsports two stage Diff / Trans cooler kit
- LG Motorsports carbon driveshaft
- Exedy twin disk clutch
Suspension
- LG Motorsports Mono ball control arm kit
- LG Motorsports G2 coil over package
- GM T1 sway bars with LG end links
- Caster/Camber kit
Aero
- GM C5 'box car' body work
- ACP front nose and splitter with under tray
- L5 Motorsports rear fenders
- ACP side skirts
- LG GT2 rear wing and frame mount
Wheels/Tires
- ForgeLine GA3R wheels
- Hoosier or Continental tires depending on events
Brakes
- PFC Z31 front and rear brake kit
- Cobalt Friction brake pads
#14 at MSR 1-15-16
Captain Buddha (01-22-2016)
The Box Cars could very well be the most collectible C5 Corvette. They're well documented and it's going to be very hard to counterfeit one. Danny Kellermyer has all of the data and information on these cars. He is the Box Car Guru.
Here's the history of these cars.
Speaking of lost history. Here's the LS1 ASA engine that very few know about.
Keep in mind that at one point you could have purchased an L88 for around $2,000. They were loud, they overheated and were no fun to drive around town.
We never really know what's going to be collectible.
Richard Newton
Richard Newton
The following 2 users liked this post by rfn026:
athornt2 (01-30-2016),
Love it!
Anthony recommendations on pinning cam bearings?
Bushing the lifter bores really make a difference on maintaining oil pressure or whats your reasoning?
THANKS
THANKS
Former Vendor
The bushings in the lifter bores can make sure you have a better clearance for the lifters, especially when running aftermarket units. This car for example, use a Comp short travel link bar style lifter in it so you can offer a smother, more consistent path for them.
It's a track car only, will never see street use. So a lot of high load and higher temps. While cam bearings are generally not an issue on a new block, we have seen them move in the past and when doing new bearings in a block pinning them makes sure they do not move on you.
