piston slap/knock sensor/ forged pistons??
I have a J&S electronics knock module. I have never heard reference until the other day just reading up on the unit and people's experience. They were talking about Forged pistons have piston slap and it creating false positive knock on the sensor. I've never used the unit but I intended to use it on my new engine but the engine uses forged pistons... Is this a problem that I need to look into? Don't LS7's and new LT1's have forged pistons and still use a knock sensors? The Le mans cars have 4 knock sensors iirc.
Just any ideas you can give me or insight before I go incorperating this into my setup.
Well designed forged pistons should be quiet when warm. A couple minutes of warm up is good. Skirt length and taper are considerations and you would be amazed the companies who doesn't get it right who otherwise have a well known name. Message me if you like and I can assist.
Once engine is at operation temp. there should be no piston slap. At that point pistons should has expanded where the excessive clearance is gone. So if it was set up by piston slap knock count should fade as engine heats up. Piston slap will sound similar to a noisy lifter.
Some good info here. To add definition to this: Valve train is constantly sewing machine sound where piston slap is more guttural and entirely more annoying. Sewing machine valve train is caused by fast closing exhaust lobe ramps slamming exhaust valve against seat and ringing through thin wall headers. Piston slap occurs most when engine is loaded less than half throttle and often transition between...think mild accelerate/decel part throttle. . Wot loaded, the piston it's not rattling about. If you are still hearing something at anything near wot, pistons are likely hitting the heads. Generally .035-.040" piston to head static cold depending on stroke and resulting piston height.
Some good info here. To add definition to this: ...Piston slap occurs most when engine is loaded less than half throttle and often transition between...think mild accelerate/decel part throttle. . Wot loaded, the piston it's not rattling about. If you are still hearing something at anything near wot, pistons are likely hitting the heads. Generally .035-.040" piston to head static cold depending on stroke and resulting piston height.
We recommend 0.006" or less piston to wall clearance.
Torque the sensor to 15 ft lbs.
The Universal version for distributor ignition has a FI/NA mode switch. In NA mode, I set the software to disable knock retard if the onboard MAP sensor sees more than 15" vacuum. For FI, it disables knock retard if more than 5" vacuum.
In either mode, engine must be above 1250 RPM.
The Interceptor and Vampire versions for coil on plug do not have a NA/F1 mode switch, so I have to program it before shipping for FI or NA. On these versions, knock retard is disabled if the engine is below 1750 RPM.
These trip points can be custom programmed for a slight charge, but you will have to send the unit in.
63Corvette (07-17-2016)
