Kumho V720 265/18-305/19 Thoughts?
Just wondering if anyone has tried this setup as an alternative for C6Z06 wheel tire for 200TW class? This may be an alternative until the 305/19 Re71R are available.
Here are some setups:
C6/C7
Front, 275/35-18 R-S3 tire, on a 18 x 9.5 56mm wheel
Rear, 305/30-19 R-S3 tire, on a 19 x 11 79mm wheel
C5
Front, 275/35-18 R-S3 tire, on a 18 x 9.5 54mm wheel
Rear, 305/30-19 R-S3 tire, on a 19 x 11 58mm wheel
Over-the-counter wheels can be found but they are not lightweight wheels:
Oz Superleggera III
Front, 18 x 9.5 59mm (with spacer)
Rear, 19 x 10.5 59mm (C5)
Rear, 19 x 11 75mm (C6 and C7)
C6/C7
C5
Oz Superleggera III
Looks like June 11/12 in Fontana will be the first chance. They are mounted and ready, I'm running 255/40/17 on 9.5 in front and 305/30/19 on 11 in rear.
Ok so I ran them today at the unseasonably cool El Toro. I run in CAM-S because of wheel width but my C5 is only built up for A-Street, stock with a Strano front bar and Koni yellows. Previously I had a 315/30/18 Rival S on 18x10.5 square set up, so the Kumhos were giving up 6 sizes in the front with the 255/40/17 on a 9.5 front and a 305/30/19 rear. In my and my co-drivers opinion, the car felt slightly faster, much better balance, going from fairly tail happy with the Rivals to a little understeer on the Kumhos. You can tell the Kumho sidewalls are stiffer. The Kumho surprised us with its ability to put power down again I think slightly better. I think the 265/35/18 Kumho on a 18x10.5 on the front would be even better. I'm going to run them again next weekend in 100 degree heat at Fontana so I'll know more then...
JLZ06TR (06-14-2016)
