Running a square setup 315 on all four corners?
Hi All, currently I am running 275 18" upfront and 315 19" in the rear on my C6 Z51. Is anyone running a square setup? I use Hoosier R7's and I am hoping they will last a little longer if I can rotate them by going to the same size all the way around. Is anyone doing this? What are the disadvantages? Understeer or oversteer? Can I fit 315 on the front? Anything else I should consider?
Square is great for rotating and traction, but on a narrow body C6 if it is lowered your max width will be 305 square and even then you will have a lot of rub in the pits and some on track over big bumps.. Lots of rub. 295 is a lot more reasonable in the front.
Thanks for the response Jerry. I did lower the car recently when I put LG coilovers. Im thinking I might got 295 all the way around. Do you run 295/ 30 -18's? I have to see what size hoosier offers.
I have the LG G2 coilovers as well (love them!) and run 305/645/18 Pirelli slicks and my inner fenders are worn through as a result. Its a lot of tire but I love the front end grip. When I go to Hohos it will be 295's yes but I've read the new R7/A7's run wider then previous generations so they may be just as wide as the 305s I currently run. If the threat of rubbing scares you step down to 285 Hohos.
RobbyZ (05-05-2016)
RobbyZ (05-05-2016)
Junglepeanut (05-28-2017)
for the track I run 315 square on my C5Z06 on OEM rears 18x10.5. and I run a bigger front sway bar to help offset the extra oversteer. works great. id imagine it should work great on a C6 too.
In dry lowering pressure increases the contact patch to gain grip; In wet raising pressure increases the water evacuation of the contact patch to gain grip
Is it me or does that tire pressure advice look like what youre supposed to do in the rain - not the dry unless the tires sidewalls were rolling over.
But from 1986? Wasn't everybody running BFG T/A Radials??
j/k I know they had Gatorbacks, and I remember my Dad got some of those newfangled Yokohama A008s for his 911. That was the hot tire for a while
I think you're right, that's the old street tire pressure for edge roll advice, not the newer tire pressure for spring rate.
I don't think physics has changed over the years, though.
Stiff end tends to continue in a straight line.
They were all radials, I had gatorbacks on my shelby charger, and proxes on my stealth.
Maybe the sidewalls were more flexible back then. I do remember people running Hoosers ran in the low 20's for psi.
Shane
I did have to do some cutting in the front wheel wells but by that time, the entire car was gutted out anyway.
Worked for me
Thanks for all the advice guys. I am finally getting around to buying new tires, but I want to reuse my front 18x9.5 with 56 offset wheels and a 295 tire. That way i dont have to rebuy another 2 wheels to go square. Is that too much of a stretch? Anyone else running R7's 295's on a 9.5" wheel? I need to double check to make sure Hoosier offers 295's in 18".
