NASA ST3 OEM-aero Technical Bulletin 5-4-16
Location: If you don't weigh in you don't wrestle Road America
For those who haven't seen this:
So it looks like if you want ZR1 aero bits you're going to have to start with a ZR1 or a Z06.
TECHNICAL BULLETIN 5-4-16
ST3 "OEM Aero" Modification Factor
7.3.2
D) ST3 Only Production Vehicle Aerodynamics (does not apply to ST1 or ST2 vehicles)
Production vehicles that maintain their unmodified OEM trim model body lines and do not have non-OEM aerodynamic aides or modifications may assess the Modification Factor for “OEM Aero” in calculating the “Adjusted Wt/HP Ratio” (7.4). Under this specific rule, an aerodynamic aide is considered non-OEM if it did not come configured on the vehicle from the manufacturing factory on the competing vehicle's trim model. There is no updating or backdating across trim models or the addition of dealer installed OEM options permitted.
Some examples of items not permitted under the "OEM Aero" Modification Factor would be the addition of Z06 or Z07 Aero aides to a base trim Corvette, or the Laguna Seca Aero package on a Mustang GT.
7.3.2
Silver -V- (05-05-2016)
