3-pt seat belt clip?
What do you call, and where can you get, the h-shaped clips that make the factory seatbelt not slip loose across your lap? I'm not yet ready to spring for a full harness, but want better holding power.
A CG-Lock is better than the h-clips and very affordable. It will actually lock the lap belt to the shoulder belt and give great holding power. I have used them for years in my own cars as well as student cars.
I bought mine off Amazon, but their website is cg-lock.com
-Kevin
-Kevin
mxk (05-06-2016)
-Kevin
-Kevin
Received 8,918 Likes
The Corvette has a standard cinch feature. You don't need to buy anything. To use it effectively run the seat all the way to the rear using the exit button. Then pull the seat belt out all the way until it stopped. This puts it into cinch mode and as you let it go back into the take up reel you will hear it ratcheting. Latch the belt and pull the lap belt tight with one hand while using the other to feed the added slack in the shoulder belt back into the take up reel. When you have the lap belt and shoulder belt as tight as you can get them then move the seat forward to your seating position and save that position into seat memory. I usually tell people to run the seat forward until it feels like the lap belt is going to cut them in two and the shoulder belt is restricting their breathing. Then it is just about tight enough. With the improved seats in the C7 this will hold you in place through some pretty high G level maneuvers. If I have a passenger I usually stand outside the car and once the belt is in cinch mode grab the shoulder belt and use my body weight to pull it and the lap belt tight and then have them move the seat forward. By the way this has been a feature on Corvettes since the 1984 model was introduced. It didn't work as well on the C5 and C6 because the seat didn't have anything to hold you in place. The seat is supposed to hold you in the car and the belt is supposed to hold you in the seat.
Bill
Bill
mxk (05-06-2016)
Bill
Bill
It locks the two together.
Bill
