Direct replacement Hats & Steel Rotors for C7ZO7 CCM's
Former Vendor
St. Jude Donor '13
If you have been tracking your car and have experienced issues with the CCM pads and rotors NOW we have Direct replacement Hats & Steel Rotors for C7ZO7 CCM's
GIRODISC FRONT 2PC ROTORS FOR C7 Z07 WITH OEM CCM ROTORS
The Girodisc system is a direct replacement for the OE disc however a different brake pad with an annulus (pad swept area) of 66mm or less must be used. This is done to keep the rotor weight at a reasonable level. If we manufactured a rotor with the same annulus as the OEM CCM rotors they would be far too heavy. The necessary pad shape is the same that is found in the standard Z06 brakes that came with the iron rotors from the factory.
The central hat section of our rotor is made from strictly U.S. sourced 6061-T6 aircraft specification aluminum. The disc is made from our own proprietary cast iron, poured in the USA and machined from start to finish in house at Girodisc. The rotor utilizes a curved vane design, developed in racing to act as a centrifugal pump to force cooling air through the disc.
The rotor and hat have a floating mount system, which utilizes 8 or 10 high strength alloy steel drive pins, manufactured by Girodisc in the USA to our own specifications and cadmium plated for a long lasting corrosion resistance. These pins take the load from braking actions while maintaining the axial and radial float between the hat and disc. The pins are secured by grade 12 cap screws with hardened washers. In order to keep the rotors from making noise when cold, the pins are mounted with anti-noise spring washers on the rotor side which allow the rotor to grow with heat expansion but eliminate the rattle and noise associated with floating rotors. This float also allows the rotor to self center between the pads.
Once the Girodisc system is in place, simply replace the cast iron rotor when needed.
Sold/priced per pair
GIRODISC REAR 2PC ROTORS FOR C7 Z07 WITH OEM CCM ROTORS
The Girodisc system is a direct replacement for the OE disc, no modifications are necessary. The disc will bolt directly to the car and work with OE calipers and parking brake without issue.
GIRODISC FRONT 2PC ROTORS FOR C7 Z06 WITH FACTORY STEEL ROTORS
GIRODISC REAR 2PC ROTORS FOR C7 Z06 WITH FACTORY STEEL ROTORS
We also have Race/HPDE/Street pads available
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
