Spring Rates for C5 - Street w/ occasional track time
Hello all,
Just bought a C5Z and plan to get some coilovers to replace the transverse leaf spring setup. I've done alot of digging on the forum and haven't found a ton of info on suggested coilover spring rates (linear) for the C5 chassis.
This will be on a street car that seems some HPDE and auto-x time. I'm comfortable with a firmer and slightly more jarring ride, but don't want to go all out race-car with the spring rates. (*I'm looking for something firmer than the stock C5 Z06 rates but not as firm as a dedicated track car)
Basically, what are some spring rates for front and rear I should be considering that are a happy medium and streetable?
Rodney@ridetech (05-26-2016)
For what you're doing the stock springs are fine. If you wanted to go a bit stiffer, bigger bars are probably the way to go. I'd suggest the Johnny O'Connell bars since that gets you a bigger front bar and an adjustable rear bar that you can adjust to dial the car in. T1 bars are often described as being "too stiff for the street", and the Pfadt aluminum arm bars are junk. Here is a link to the Pfadt sway bar chart that will give you a better idea as to how far to go.
http://pfadtracing.com/pdfs/Corvette...omparison.jpeg
Johnny C @ OG (05-23-2016)
What characteristics does the car exhibit now on stock springs that you are hoping to rectify with changed spring rates?
Until we know that it's a bit tough to make suggestions on what way to go with springs.
I've been pretty happy on stock springs and using single adjustable ridetech shocks and strano swaybars. The car is still comfortable on the street and regularly runs laptimes on street tires that would be competitive at most NASA TT events.
I'm primarily looking to get a coilover system for ride height adjustability and corner weighting option, but am unsure what range of spring rates to look at.
Car will be full street weight with no weight reduction, 285F 315R street tires. Would like to stiffen up the car to reduce body roll and improve feedback.
stock leaf springs are height adjustable for both ride height and corner balancing purposes.
I found ridetech control arm bushings to be a big improvement in steering feedback. and larger sway bars do wonders for body roll without adding any harshness on the street.
Regarding coilovers I'm not going to be much help as I've mostly been researching leaf spring upgrades but I'm sure someone will chime in soon with some suggestions.
You're willing to corner weight the car and any good shop with a set of scales can do it. The quickest and easiest way to do that is to put a jack under the front spring on one side and turn the adjusting bolts on the end of the springs in complete turns about half way from where they are stock to where they would be "bottomed" out. As I said, turn each front screw an equal amount and turn them in full turn increments. Then set your corner weights and rear ride height with the back screws since they can be done with the car sitting on its wheels. Remember to keep between 1/4 and 1/2 an inch of rake in the car as measured at the jacking points on the frame rails.
As we've all said, the springs on the Z06 are well matched to the car and really, the best thing you can do is just increase the roll stiffness a bit and you'll be about as stiff as is acceptable on a street/track car. A good set of shocks with some adjustability is nice as is some adjustment to the rear bar.
The C5 Z06 is about as close to a dual purpose car right out of the box. Most folks who try to make them faster with coilovers and messing around with the suspension end up screwing up the handling more than they end up helping it. I can't tell you how many cars I've driven at track days and autocrosses that were slower than a properly set up stock car.
One other point. A serious track alignment with negative camber and a bit of toe out really wakes these cars up. The difference between a factory alignment and a serious set up with the car lowered a touch and properly aligned is like night and day. Add a set of serious tires and you've got a car that very few can catch on the track, but you can drive on the street an not need a kidney belt if you live in an area where the roads aren't billiard table smooth.
You might have some trouble on this one. Most Corvette coil overs are made for track cars that need additional spring rate to handle the increased down force from aero. The leaf spring setup is actually great for the street, and hard to beat for the track if you don't have aero. I don't know of coil over package off hand that is made with a street focus.
Ok, after doing more research, I have two questions:
1) Are the spring rates mentioned/quoted for leaf springs directly equivalent to a coil spring? (And are the leaf springs linear?) IE - is a 600lb/in leaf spring = 600lb/in coil spring, or is there a difference in behavior?
2) I am hearing two schools of thought on the C5 chassis setup --- stiffer springs in the front versus stiffer springs in the rear. (IE - 1000lb front 850lb rear vs. 650lb front 790lb rear). Why is this and can you share some thoughts or experience?
I run the hypercoil track spring on the front, street spring on the rear, JRi double adjustable shocks, Sam Strano front and rear adjustable sway bars on 18x10.5 wheels f/r along with Bridgestone re71r front BFG Rival S rear tires. Car is compliant on the street (i.e. girlfriend doesnt complain) yet is well mannered on the autocross course and neutral. I like it. It should get even better when I get new upper control arm bushings. I see no need for coilovers unless you have a lot of AERO on the car.
Pro Mechanic
Wow. 5 days, but no one has any REAL information?
I have a C6Z with LG coil overs on it, rides better than my stock C5 no question. Unfortunately, Hyperco springs have the rate etched on the end instead of stenciled on the side, and I'm not planning to take it apart just to look.
Coil overs give you a cheap and easy tuning tool via spring rates. Leafs don't exactly come in 50lb increments...
Contact LG or Doug Rippie? I'd like to know the answer myself...
determining required spring rate is all about the maths !
buy yourself a chassis engineering book, any decent book will explain the maths and the measurements you need to take, including things such as wheel rate, motion ratio, corner weights and how to come up with the required figure.
if that all gets too hard, find someone who sets up race cars and take the measurements to them, and if you have to, just pay them for their time and walk away with your required spring rates and sway bar rates.
this thread has a lot of useful information:
https://www.corvetteforum.com/forums...ld-thread.html
The day is finally here! Hi guys, this is Lane Borg (ltborg on the forum) and at last I can announce why I have waited so long to post a build thread on my STU car. As you can see, I am posting as Borg Motorsports and as of yesterday, I am officially a proud Supporting Vendor! I’ve been on the forums for over a decade under the ltborg handle and will still be active as a private member, however I am extremely excited to also be here a vendor!!!
In the search for the perfect parts for my STU car, I found no one was really doing what I needed. When I looked at getting parts made, the costs were prohibitively expensive. At one point I caught myself saying, "I can probably buy a CNC for what this will cost me." Little did I know where that off-hand comment would take me. Eight months later, I am officially opening the doors of Borg Motorsports. As many of you know, I have been a forum member here for over a decade. Hopefully you have read my B-Street Build Thread about my car's journey to the first B-Street Solo National Championship in 2014. If not, check it out!
As an engineer whose thesis covered suspension modeling of a race car and who specialized in mechanics of materials, I plan to bring this knowledge to the Corvette community by offering the products I have always wanted to see in the marketplace. I have (and still do) work as a test driver/engineer for the Goodyear Tire & Rubber Co. where I work on both internal projects as well as supporting OEM programs. I plan to use this automotive testing experience as well as my detail oriented design philosophy to improve the performance of our Corvettes through modern day American manufacturing and design.
Please bear with us as we get our website up and running. I'm primarily working on ramping up production of our first products at the time as well as planning the second (and third and fourth) in preparation for the 2015 Solo Nationals, but I have others working on the site, photos, etc. I plan on writing all content myself and am the only person that will be posting under the Borg Motorsports handle, so a little patience in the early days would be appreciated. I strongly feel doing this will provide the highest quality information and products to the Corvette community. I hope to prove to be as good a vendor to the forum as I have been a member, thanks for having me.
This thread will be about the design and development of the Borg Motorsports STU car. I ask in the interest of keeping the thread on point that you post questions specific to this car or our products here, while posting general STU build questions in the already existing STU Build Thread. With that, let's move on to the build!
____________________
Introduction
ST classes are simply too cool to pass up. High class participation, high driver talent, and just the right amount of mods to blame the car when you lose. I’ve wanted an ST class for Corvettes since I started autocrossing semi-seriously in 2005. In 2014, my wish was granted and the C5 was allowed into STU. While I had committed to B-Street already, I was excited at the prospect of running STU in 2015. I thought about it for most of the 2014 season, and while the yellow beast did well in the newly created Street class, it just wasn’t quite right; in a lot of ways, it wasn’t quite right in A-Stock either. There was just something missing. I wanted my car to be a C5Z; something that was more than the sum of its parts, something more fun than it looks, and something that would challenge me more than a Street car in terms of setup, car design, and driving abilities. STU looked like a pretty good solution.
Shortly after winning the first B-Street National Championship (and after a long talk with Sam Strano having him check for ID10T errors), I decided I had to build my car for STU.
While excited, I still had lingering concerns about a potential lack of competition with the reigning champion (Brian Peters) leaving the class. I figured that would allow me to ease into the world of national level non-stock autocross cars. Little did I know what sort of field was about to unfold in the class for 2015. Apparently, my talk with Sam about the C5 was enough for him to think it was a good idea too and he bought a former AS car (albeit not for his regular National events). While Peters left the class, he filled me in that his car was sold to, “some guy out west.” Well that guy turns out to be Bryan Heitkotter, contract driver for Nissan. If that wasn’t enough, the 2014 C-Street winner, Jeff Stuart, bought a 350Z to run in STU. Lastly, Jon Lugod of OS Giken announced that he would be developing the factory OS Giken C5 for STU. John Hale is back in the picture in a WRX and there are already potent competitors running in the AWD crew like 2014 Nationals runner up Mark Hill and Robert Pendergest. So much for easing into things…
I’ve already posted a B-Street Build Thread that has all the information on that version of my car as well as some of my background and experiences. Take a look if you want to get up to speed.
All of that leads me to the point I’m at now, building a no holds barred STU C5. I want it to be easy and comfortable to drive, it should be a track day rockstar, but first and foremost it will be built to the ragged edge of the ST rules. If something on the car can be made better, I will make it happen. Time to turn things up to 11.
The Plan
As I mentioned before, the build is meant to create a car that is an all out STU build, with strong track day and time trial performance. The build plan starts with the car’s strengths and weaknesses in BS trim.
The Good
The Bad
In order for the build to succeed, I would need to capitalize on the good aspects of the car, and minimize the effects of the bad. Generally I have found maximizing a strength to be better than minimizing a weakness, but if you can do both, all the better.
With the project goals in mind, I set some objective performance targets for the car:
As well as some subjective goals:
With those goals in mind, let's start looking at specifics.
Wheels and Tires
ST is essentially a spec tire class. For all the talk of which tire is fastest, once the fast tire is found, everyone runs it since tire size is mandated by the rules. With everyone (presumably) on the same tire, the design objective is to maximize the mechanical grip of the tire. This means the tire must be properly supported by the rim and properly oriented to the road surface in a dynamic condition. These items will allow the tire to be run at a much lower pressure than normal, maximizing mechanical grip. At some point, a lack of pressure will cause the center of the footprint to collapse into the tire cavity, reducing the total footprint area or, at a minimum, making the pressure distribution within the footprint less optimal.
The first item is to make sure the tire is well supported by the rim. A wider rim provides a given tire with more grip due to the increased rim support. Obviously a tire intended for a 6.5" wide rim won't fit on a 13" wide rim, but going to the larger side of manufacturer recommended widths is certainly advisable. The tire size limit in STU is a section width of 285. Nearly all manufacturers of 200 treadwear tires only offer this sort of width in an 18" tire. TR&A guidelines for a 285/35R18 (the most common 285 size available in the selected tires) advise a rim width up to 11". For the current iteration of the car, I decided to go with 10.5" wide wheels. This size wheel does two things for me. First, it significantly decreases the cost of a set of wheels which greatly helps the budget. Second, it allows for 275/35R18 tires to be run as the TR&A specifications for that size are a maximum rim width of 10.5". This give me more options of tire manufacturers. Pressures will be determined through tire temperatures during testing as well as subjective feedback of vehicle performance. More on this in the testing section.
I selected TSW Nurburgring wheels that measure 18x10.5 with a 65mm offset. The extra offset allows me to play with different track widths and keeps the big tires well under the stock fenders, which I am not allowed to change (you can roll stock fenders in ST, but that doesn’t work so well on fiberglass…).
Due to avoiding any possible conflicts of interest, I will not be posting my tire test results. That said, I will make sure you know what I am running. I know this might upset some people, and I am sorry for that, however I enjoy my day job and Goodyear as a company and I will not be compromising that position.
So far in 2015, I have been running the Bridgestone RE-71R’s in 275/35R18. I think the current National results have shown why I am running this tire. With stock bushings and aftermarket springs, I ran 30 psi front and 28 psi rear. Current pressures with the prototype offset bushings are 28 psi front and 25 psi rear. 24 psi in the rear resulted in less than progressive slides and reduced sliding grip, but more on that in the bushings section.
Differential
Now that the wheels and tires are sorted, it’s time to look at the center of the vehicle design. In the case of ST, that means the differential. A differential can have a HUGE effect on the handling of the vehicle. For this reason, it is important to get the diff sorted out first and tune the rest of the car around it. I have chosen a gear type differential for the car. At this time, I am not willing to share what version it is as I don’t want anyone to run out and get one, just to find out that there are durability or performance issues. I don’t release my products until I am VERY comfortable with their performance, and likewise I don’t want to endorse a product until I am 100% confident in it. I will however explain why I chose a gear diff over a clutch type.
This is where some real engineering comes in. Please keep in mind that my design philosophy isn’t always centered around what feels good. If it gets me a faster lap time at the expense of feeling good, I’ll take it. Let’s start by looking at how a locked axle and an open differential work.
On corner entry, an open diff allows a differential in rotational speeds of the rear tires. This means there is no resistance to rotation when entering a corner, creating a balance more towards oversteer (or less understeer). Due to this lack of resistance, there can sometimes be some instability during braking. A locked differential on the other hand prevents the wheels from rotating at different rates and creates a resistance to vehicle rotation, thus the vehicle is more balanced to understeer on entry. A byproduct of this is increased braking stability.
On corner exit, an open differential applies torque evenly to both tires until the inside tire’s traction limit is reached. At this point, no additional power can be put to the ground as the power takes the path of least resistance (the inside spinning tire). This limits the forward thrust to the amount of longitudinal grip of the inside rear tire, which is more lightly loaded than the outside tire (often significantly so). In a locked differential, both tires are forced to spin at the same speed and the power application is limited by the grip of the outside rear tire. This is a large advantage over the open differential as the outside tire will have much more load than the inside tire and thus, will have much higher longitudinal capacity, resulting in a higher forward thrust than the open diff. So at this point, you might be thinking that we need a locked diff (clutch type), but let’s look more closely at the situation on corner exit.
A locked differential may have a higher capacity for forward traction than an open differential, but the force applied will generally be fairly equal on both rear tires. This is a great thing for straight line acceleration, but we are exiting a corner in this situation. By having equal forward forces on the rear tires, the forward thrust is creating a resistive moment to the vehicle rotation, ie. the acceleration is helping to prevent vehicle rotation. Again, this is great in a straight line, but it is not what we want in the tight confines of an autocross course. When I hit the power, I want the car to be able to put power down AND rotate. Please note that rotate and oversteer are not one and the same. Oversteer (rear axle sliding) by definition contains rotation; it is an over rotation of the vehicle. Yaw rotation however does not necessarily mean oversteer, it simply means the vehicle is turning (not necessarily sliding). Enter the gear diff.
The geared differential, know commonly by the brand name Torsen, is a differential that splits the input torque to the wheels based on a bias ratio. The bias ratio determines how much more torque is applied to the wheel with more grip. If a differential has a bias ratio of 3:1, the outside tire will receive three times the torque of the inside wheel. The bias ratio is determined by the internal gears and is generally not something that is easily tuned once the diff is built. So long as the inside wheel is not being lifted off the surface (which it shouldn’t be in a RWD car), the inside tire will get a certain amount of torque and the outside wheel will get three times that in our example. This situation results in a greater thrust force on the outside of the car than the inside of the car. When this happens, the car pulls to one side, in this case, the direction of the turn. This ADDS to the rotation of the car and allows the driver to get on the power sooner and turn the car with the throttle, not by sliding the rear, but by pushing the car forward, exactly what we want to be doing. So in theory, the gear diff is what we want, but what about in practice?
Examples of cars that use Torsens (or equivalent) today include the critically acclaimed 2015 Z/28 Camaro, the ever popular FR-S/BRZ, and reigning STU National Champion Brian Peter’s 350Z. In his book recalling the many stories of his lengthly racing career, Corvette crew chief Dan Binks discusses how the Torsen differentials were always faster for his cars, but they were not up to the task of an endurance race due to the heat build up from the internal friction inherent in these designs. Luckily for us, autocross competition doesn’t involve the long runs that endurance racing requires.
For all these reasons, I chose a geared differential for the car. For those of you worried about what happens when the inside tire lifts:
1 - There is no reason for a Corvette to lift a rear wheel in ST trim. If it does, something is very wrong with the car or the setup.
2 - Most gear differentials manufactured today have devices that allow some lock at low inside tire loads.
Now that the differential is in the car, it’s time to get the balance correct.
Springs and ARBs
Sadly, ST rules do not allow the use of coil overs on cars not originally equipped with coil over shock configurations. This limits us to the use of leaf springs. Only two companies currently make aftermarket leaf springs, VB&P and Hyperco. I have tested both and settled on VB&P springs. Let’s talk about target spring rates and how leaf springs differ from coil springs in terms of setup before getting into the specifics.
Leaf springs get a bad rep. Yes, technically speaking a form of leaf spring was used on Vietnamese ox carts as a famous presenter once pointed out, however traditional leaf springs are very different form those used on the Corvette. In addition to the mono-leaf design which virtually eliminates internal friction, the Corvette mounts the leaves transversely. This mounting method means that the leaf spring will be slightly softer in ride than in roll. In other words, the spring acts as a spring AND an anti-roll bar. This allows the ARB’s on the vehicle to be smaller and lighter than they would be on a car with traditional coil springs. The result is a very light setup, but a slightly more difficult setup to tune. The stock Corvette leaf springs have a constant profile. The Hyperco springs have a constant profile. VB&P rear springs do NOT have a constant cross-section. This gives the VB&P rear spring a larger difference in ride and roll rates. Until I make a test rig that can measure ride and roll rates (which is on the to do list), testing and tuning will be the only decent option to determine the effect of the different springs. For a fairly good explanation of how the Corvette leaf springs create different rates in ride and roll, please see the Wikipedia page on leaf springs; the section on leaf springs as an anti-roll bar is very good.
Moving on to the testing of these springs, people always complain that VB&P springs are “too stiff” without any data to back up this claim. Sure saying, “I run 1200 lb springs on my car” sounds stiff, but is it? We all know the spring manufacturers measure their springs differently and that can lead to different values of spring rates for what should be the same springs and vice versa. What people forget to talk about is that one spring on the Corvette controls TWO wheels, not one. Suddenly, that 1200 lb spring is split over two wheels and you aren’t nearly as stiff as you thought. I wanted to confirm this with real numbers, so I have measured every spring I own on my car and measured actual ride rates. Please note that the roll rate will be different for the reasons discussed above. The table below shows the claimed spring rate, the measured spring rate, and the measured wheel rate. I have included coil spring calculated examples from coilover kits in the wheel rates as well as a point of comparison (all measurements in lbs/in).
As you can see, a “super extreme” 1500 lb/in front leaf spring is barely stiffer than a 500 lb/in coilover setup. Lots and lots of people run 500 lb/in coil springs on coilovers, with many of the track only guys running even stiffer than that. The spring may be very stiff in roll, but that is simply adding more ARB to the car, something we want anyway.
I have tested the following combinations of springs on the car with STU tires:
Hyperco HPT front/HPS rear, stock diff - Good balance
VB&P 1500 front/900 rear, gear diff - Loose balance
VB&P 1500 front/770 rear, gear diff - Good balance
Currently the car runs the 1500 lb/in spring in the front with the 770 lb/in spring in the rear.
I haven’t done a lot of testing on ARBs, but currently I have Strano Parts 33mm hollow front and Strano Parts thin walled adjustable rear bar. The rear bar is supposedly close to stock in rate, but adds adjustability. I run the front bar full stiff and the rear bar full soft. Once I develop my own bars (third product on the list), I should get things dialed in even more.
For a cheap, but easy to drive setup use a Hyperco HPT front and the Strano 33mm hollow front bar with the stock rear bar and spring. I think that will get you 70-80% of the way there at a much lower price point than an all out build. If you like your cars to be slightly on the loose side, use the HPS rear spring with the above combination. Equivalent VB&P setups would work as well.
I’d love to go stiffer, but have physically run out of room due to the thickness of the front spring. Long term, I may work on a solution for that, but for the foreseeable future, I’ll be running the above VB&P springs.
For those of you wondering about how low the car is, the car sat higher in STU trim with this stiff front spring than it did in BS trim, even with the stock adjusters. I created some new low-profile adjusted for the VB&P springs that use a thin Delrin AF pad to replace the stock ones. This allowed the car to sit nearly a quarter inch lower than with the VB&P adjusters and got me back to slightly below stock ride height. I then thinned the spring pads on the top of the front spring, lowering the car further to the front ride height target. The rear ride height is extremely easy to adjust by changing the length of the bolt. The rear spring has Delrin mounting pads as well to replace the stock rubber ones.
Shocks
This section is here just to cover any questions. I am still running MCS 2-way dampers, just as I did in BS. They are set to 3/9 front and 2/9 rear (compression/rebound). I have not done any tuning with these on the car yet. I looked at the shock plots and took an educated guess at about where they should be, then left the car as is. I will update this section as time goes on.
Bushings
We all know the stock Corvette suspension bushings leave something to be desired. While the late-03 and 04 bushings are better, they are still not the greatest. With that in mind (and as a means of testing the manufacturing equipment), I designed my own set of Delrin bushings. Knowing I wanted the best possible materials, I used Delrin AF which is a Teflon fiber impregnated Delrin, giving the material self lubricating properties and virtually eliminating maintenance. Given that Delrin has a very low yield strength compared to aluminum, I wanted to use as much metal as allowed in the bushings to spread the loads in the Delrin over as large an area as possible. All of the stock bushings were measured and metal percentages were calculated. I used this information to standardize a center metal sleeve for all the bushings. In non-adjustable locations, 6061 aluminum met the structural targets while also reducing costs. In the eccentric locations, I wanted to ensure added strength, thus the performance targets mandated 7075. I felt the increase in cost was warranted as a means to make the car as reliable as possible. 7075 was also used for the upper dog bones, allowing me to built in a significant offset into the mounting location of the a-arms themselves.
In addition to offsetting the dog bone mounting offset, I offset all bushings on the car. The reason for this is that the maximum camber I could achieve on the car was -2.2 in the front and -1.4 in the rear. Knowing I would want to optimize the tires as much as possible, I set targets of -5 in the front and -3 in the rear to give me the range of adjustability needed to test and optimize the tires engagement with the road surface. I was able to hit -4.7 in the front and -3 in the rear on my specific car.
These bushings have proved to be a HUGE improvement in the feel of the car. Slides are more progressive and steering response has improved. Despite zero alignment tuning of the car, I would have placed fifth and third in top PAX (minus those pesky cones from my lack of sleep) at the two National events I have attended since installing the bushings.
Many people will ask how the eccentrics are dealt with in a Delrin bushing design. I took great care to measure all the factory tolerances and determined that matching them would allow just enough movement of the bushings to allow the eccentrics to work. Prototype bushing sets were used to validate these calculations. After making some minor adjustments, the tolerances of the sleeve to Delrin interface, along with the tolerances of the bolt to the sleeve, allow the eccentrics to be adjusted through the majority of their range without any issues. Towards the extreme end of the adjustment range, the adjustment requires more force (ie. the adjusters feel very tight), but the bushings will still allow adjustment to the full extent of the range.
With that, allow me to introduce the first Borg Motorsports products!
Our Delrin bushings are available in three forms. For the cost conscious consumer, we have a steel, aluminum, and standard Delrin set of bushings. These bushing give you all the stiffness your suspension needs for precise and predictable handling characteristics. Standard Delrin may require occasional lubrication and the steel dog bones mean the weight of the system will be slightly more than stock.
The second set is a top-tier version of the bushings using premium materials. Standard Delrin is replaced with Delrin AF Teflon fiber impregnated Delrin. Do not confuse this with the Teflon powder version of this material. Teflon (PTFE) fiber offers improved lubricity and durability over PTFE powder filled acetal resins and non-filled acetal resins (Delrin). This kit also replaces the steel components with high strength aluminum to maximize weight reduction.
Our third bushing kit is for those drivers looking for the last tenth off their lap times. This kit includes our premium bushings machined with offset through holes allowing maximum possible camber and caster settings. While we doubt you will have to use the maximum range of adjustment, having the option is always better than not when searching for a faster lap time. This kit requires drilling and tapping of the control arms (drill and tap included).
As of June 20, 2015, Standard and Premium kits will begin shipping on or before July 31, 2015. Offset kits will begin shipping in August. Pre-orders are available now at borgmotorsports.com. Pre-orders are shipped in the order received. All pre-orders include a free Borg Motorsports t-shirt (black shirt with white single color logo, please enter your size in the comments section of the order).
All kits are available for the C5, C5Z, and C6 (steel frame). C6Z kits are in development. Once inventory is built up, these will be stocked on a regular basis. The product information of the website will be updated for each kit when this occurs. Borg Motorsports products will be available directly from us or through our partner (and fellow Supporting Vendor) Strano Parts. Professional pictures of the kit are being worked on and will be posted as soon as they are complete. For now, enjoy the photos of the prototype kits in various stages of production.
Prototype Photos
Alignment
As mentioned above, I have not done very much in the way of alignment testing. This section will be added to over time. Currently the alignment is as follows:
Front
Camber: -4.5
Caster: 7.1
Toe: 3/16” out
Rear
Camber: -2.5
Toe: 1/8” in
The car has a reasonable balance at high speeds (although slightly loose), but has a mild low-speed push, beyond what would be expected, at lower speeds. My current plan is to adjust the caster to compensate for this. The rear still needs more camber judging by various competition pictures and the accelerated outside shoulder wear. Front tire wear is extremely good. Please note at these camber levels in the front, I did have to add spacers to prevent rubbing of the inside shoulder against a portion of the inner fender on the driver side of the car.
Engine
The engine has had minimal work done to it at this time. The major bolt ons have been completed, but no tune has been performed and I have no idea what the power output is at this time. Currently the car is running Jethot coated American Racing Headers (1-3/4” primaries with 2.5” exhaust) going into the Corsa Titanium system I used in BS. The Corsa mufflers were very close to the sound limit so I removed those and added Magnaflow 10416 mufflers in front of the transmission. They just fit in the tunnel and I was consistently low to mid 90’s on the sound meter with that setup (highest reading of 93.7 dB). I have a Halltech CAI and an ATI 25% under drive pulley. All parts were sourced from Strano Parts. Tuning is planned for this summer at LGM in Plano, TX (same dyno used to measure A-Stock and B-Street cars).
Update 7/19/2015
The car made 359 HP and 362 ft-lbs on the chassis dyno at LG Motorsports. This was after the tune. For reference, the best the car did in AS/BS trim was 331 RWHP and 341 RWTQ.
Miscellaneous Items
I run a Battery Tender BTL35A480C Lithium battery. It weighs about 3.5 lbs and starts the car RIGHT up.
I have Cobra Suzuka GT's waiting to go in the car as soon as I machine some seat rails for them. Should be right at 25-26lbs with sliders. My stock seats (full power, lumbar, etc.) are 45.0 each.
Current Summary
As of June 20, 2015, the car is undefeated in National competition and regularly placing top 5 in PAX. I plan on running alignment and shock tuning prior to Nationals. I will also be installing some weight reducing items as well as the all important race seats. Thanks for reading, stay tuned for more!
Introduction
The Plan
The Good
- Lots of torque
- Good suspension geometry
- Can easily max tire/wheel rules
- Wide track for good mechanical grip in sweepers
The Bad
- The stock seats
- Resistance to heat buildup
- Wide track means slower slaloms
- Soft suspension means slower transient maneuvers
- Poor gearing for autocross courses
- Under 3000 lb race weight
- Minimum 400 RWTQ
- Capable of 20 lap stints on a road course in 100 F heat (I do live in Texas)
- Maximize torque under 4500 RPM (even at the expense of peak power)
- Perform a professional racing analysis on as many parts as possible with a quantifiable performance gain
- Subjective driving feel similar to "special" cars (C5Z, FR-S, 911, modern Z28, etc.)
Wheels and Tires
Differential
Springs and ARBs
Shocks
Bushings
Prototype Photos
Alignment
Front
Camber: -4.5
Caster: 7.1
Toe: 3/16” out
Rear
Camber: -2.5
Toe: 1/8” in
Engine
Update 7/19/2015
Miscellaneous Items
Current Summary
^ Great info, thanks for sharing.
-- So do people usually go for stiffer springs in the front (vs softer springs in the rear) for lower speed, autocross setups and reverse that order (stiffer rear vs front) for higher speed road racing/HPDE events?
Is that a general rule of thumb, or just preference?
I'm just curious because all of the factory GM C5 spring rate combos have stiffer rears and softer fronts, but many aftermarket offerings completely reverse that order.
Thoughts?
Thoughts?
Going to a totally different suspension setup (which is what you are going to do by going to coilovers) means totally rethinking the sway bar balance as well.
Since this car is not a totally dedicated track car then you are by nature going to make some compromises in terms of stiffness and alignment and you need to think about that before you go running off and buying springs and coilovers. To that end how much negative camber are you willing to live with and give up tire wear for? In addition, shocks have a bigger influence on ride harshness than springs. You can (as I can attest to) have stock springs on the car and have a ride that is harsher than anyone could possible want on the street.
Suspension setup is all about balance. In the old days cars were biased towards ride and handling could be vastly improved by stiffening up the suspension with bigger bars and some stiffer springs and slapping a set of high quality shock on the car. Those days are long gone. What you will find is that spring rates and sway bar rates for very performance oriented cars like the C5 Z06 are biased much more towards handling and that it is actually difficult to improve on them very much without going to a level of harshness that isn't acceptable on the street.
If you go to a very different spring bias (more stiffness in the front for instance) then you're going to need to significantly alter the bar stiffness to get the car balanced again. I keep talking about balance, because that is really the key to good handling. Just changing rates isn't as important as getting the balance right. Also, don't assume that when you get the new springs on the car that it's going to be anywhere close to being balanced. You're most likely going to need to put on adjustable bars at least at one end of the car and then tune the suspension to get it right.
If you have a mechanical engineering degree (like Lane does) and are willing to do the analysis to calculate total roll stiffness for various spring and bar combinations you can most likely get close to a decent setup (provided you know what it should look like on paper in the first place), but if you don't have that background and have a good suspension analysis program to do that work you would do well to spend some time talking to someone who knows what he is doing and can point you in the right direction.
You really need to talk to Sam Strano at Strano motorsports. Sam has been through all of this and is a good guy and will share with you what he knows. He can get you a complete package that is close to correct, right out of the box, and this is far more important than just jacking up the rates and hoping that you get close to a proper balance.
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
There are a number of different ways to go with coil overs which is a great thing about them.
You can pick a solid all around set that can do a lot of different things very well like our GT2's, or you can custom do a set like our G2 coil overs.
Our GT2's have been working out very well for a number of people as a street car set and as a track set. https://www.corvetteforum.com/forums...at-optima.html
There is always our G2 setup too, which you can setup with us to more closely dial it in for you or a specific use be it drag racing, AutoX, or road racing. Not only with a setup like this can you work with us on building them, but say later on you completely want to change it, they are easy to service/re-valve and you have spring rates that generally come in 50lb weight breaks from 350 to 800 lbs. Now that being said you have to have a shock that can control the spring. Springs and shocks have to work together in keeping the car under control. In some respects that is why you might see someone offering a really high spring rate setup, while others might be on the softer side. Now you still have to have enough spring to support the car, but in some cases you can 'tweak' a shock to support a stiff spring on a car and still have something that can ride "ok" to a degree. All goes back to the old saying big bars and soft springs or small bars and stiff springs.
We have always went more towards a softer spring and larger bar so the car has a bit more mechanical grip and can handle the curbs without tossing the car into the air.
Not only have we been building race cars for over 30 years but we have been building late model Corvette coil over suspension systems since 1997, so chances are we have seen it, driven on it, or won with it.
If you have any questions about any of our kits I would be more than happy to talk more about them.
