Mounting 6pt sub-straps with Marrad/Hardbar/MTI Aluminum brackets
I am looking to purchase a set of fixed back seats and being a tall driver my mounting options are most likely limited to the aluminum side mounts offered by various vendors (Hardbar/MTI/Marrad).
My question is how does one correctly mount the sub-straps of a 6 pt harness using these brackets?
I bolted the eyebolts to the side of my Marrad brackets, with the eyes facing inside underneath the seat bottom. Just used big washers as load spreaders.
For the lap belt if you get Schroth B23a fittings and bolt those to one of the unused holes in the brackets below your seat's harness holes it makes for very easy mounting.
ok this what I was thinking too, this is NASA and SCAA legal correct? the other option would be the Teamtech Jetpack harness
Call and talk to Marrad Industries. He'll have a good solution.
I'm using the Marrad brackets with the slides and side mounts and rear harness anchor system. I ran my 6pt sub straps back to the rear anchor bracket. His newer bracket has an adjustable bracket specifically for the sub harnesses. Allows you to mount the ends more forward (more under your butt, rather than behind your butt), which is more inline with the recommended angles for the sub harnesses.
Received 8,928 Likes
With the seats I am selling I had the driver side sub belts fastened to eye bolts attached to the inside of the Hardbar rails. I had the lap belts attached at the rear of the hard bar rails on a Chrysler OEM lap belt mounting bolt that had a shoulder permitting the lap belt end to swivel. You don't want the lap belt fastened so the end can't swivel.
Bill
Bill
This is what I did and what I recommend. The brackets are solid pieces, and the seat bolts are mounted through metal crossbars, not the composite floor.
