Newbie c4 owner in need of help...GRM $2016 challenge build
#161
Thanks to all of your help we are much closer and getting the car to run better. But something is reared its ugly head period and eliminating parts of the harness that are no longer needed we discovered that the knock sensor wiring disappeared into the harness and when we were tracing it it is not connected. Where does the knock sensor in a the wiring loom to go to the ECU? Thanks again to the knowledge vault. You guys have been so helpful and we truly appreciate it.
#162
Hope this helps! ( BTW, the picture is from the scans I made of the engine TPI wiring diagrams. That may be easier to read.)
#163
Once again you have come to our rescue mr. Beach. But now we have an additional problem. We've been having trouble setting timing and have now realized that the reason timing is wandering all over the place is that the ESC is non-existent. We have tracked the wiring and see where it was cut. So now we're on the search for the four wires that attach to the ESC so we can wire the loom back in to give THE ECM proper signal as to timing.
#164
A (empty)
B Pink w/Black Stripe (positive voltage feed from ECM/ENG fuse)
C Black (output to ECM, one of the few cases when the color black doesn't indicate a ground)
D Brown (ground)
E Blue (input from knock sensor).
All the wires should be located in the same plastic-shielded wire bundle feeding up from the passenger side of the engine block near the rear.
If you have problems locating the cut wires especially the output to the ECM, I can give you a pin read-out for the wiring connector readout to the ECM connector. Just let me know.
#165
Thanks again. Don't know what we would do without you . Located the plug for the ESC. Have located all wires except where the pink wire goes into the bloom. I suppose we can start at the ECM and work back ? Thanks to your help we're getting close
Good thing as we only have 4 weeks from today before we leave for the event in Gainesville Florida. you you sure you don't want to come down and join us? LOL maybe more maybe more maybe more work than you want haha
#166
The pink wire w/black stripe come off the ECM/ENG fuse. The positive voltage lead that you're looking for goes through the firewall and comes out just below and to the rear of the passenger side valve cover, snakes it way across the evaporator housing, underneath the heater hoses, across the blower motor housing, behind the windshield washer bottle ,and then up to the ESC module itself. The feed wire should be there some where even if the previous owner snipped off the wire near the blower motor. The only wire that goes to the ECM is the black wire from the ESC module.
Unfortunately, I still have the Solo event scheduled that weekend up in Virginia. As the region's Solo Chair, don't think that I can skip that event since I'm the Solo Safety Steward for the event itself. I'll be rooting for you though!
#167
We finally have success to report to the Forum. Thanks to the tireless efforts of many of you especially mr. Beachcomber we have the old girl running perfectly. At least perfect for a 30 year old L98. Pulls hard all the way up until it runs out of breath. We have chased many electrical problems and fuel injection problems that were the product of 27 years of redneck backyard mechanics. IIncluding us. LOL
We have a lot of minor things to do like cosmetics and suspension adjustments before the challenge at the end of this month. When I get a chance I'll report fully.
BrianCunningham (09-04-2016)
#168
Sorry I haven't logged in to give an update but we've been thrashing getting this car in shape for next week's 2016 dollar challenge in Gainesville, Florida. I just wanted to take the time to thank everybody who offered advice, pointers, donated Parts, and were so unselfish answering are stupid question. Also want to thank mr. Beachcomber for all of his assistants and tireless advice on putting this over all together. I know some. May not like the direction we've taken with this C4 but at least we kept it out of the junkyard as an abandoned parts car. Hopefully we will do you proud at the challenge. We certainly are going to give credit in our Livery lettering to the Corvette forum for all of their help. We are finishing up the cosmetics but I will give you a little teaser pic where we are going.
Thanks again, guys.look for a complete story and update soon
#169
Been following along on both forums... I will be rooting for guys (Corvette solidarity). It looks like there is to be some awesome stuff showing up... can't wait to see the coverage and hear rhe stories!
Be safe and have a great time!
#170
Afraid we hurt the motor and transmission pushing a little too hard. Will give you all an update when I get back home. For now a little teaser photo of how the car looks on track
Total budget under GRM rules....$981.00. So next year we'll have over $1,000 to throw at it and maybe get a much better suspension and some tranny work.
The really good news is we got weight down to 2,750 pounds!!!!!!
KBoltz (10-03-2016)
#173
http://classicmotorsports.com/media/...ngeResults.pdf
Looks like you came in 20th place out of 41 entries, would say you did pretty darn good for your first effort
#174
So it could have been a top ten car and we felt we let the car down and the Corvette forum. But will know better next year. LOL some pictures for your consideration.
#175
Subaru justy body mounted on Mustang GT chassis. 1 the autocross with a high 39-second run. Call the justang
a local Mississippi Distillery donated half a case of vodka 4 Hour after party
overall winner. 68 Volkswagen Beetle body mounted on homemade tube frame chassis powered by a small block Chevy. Ran a 10.2 second quarter.
#176
Nice Job and the car looks great! I'm sure you guys were dead tired scrambling to get the it ready let alone the extra work during the event.
Matt
Matt
#177
Here's a link to Art Carr's recommendation on setting the manual T.V. cable on 700R4's. This should correct the shifting problems we discussed over the phone.
I'm working on copying the Code 34 trouble-shooting guide for you. I was wrong in that the MAF Burn Off relay sets a separate code (Code 36).
#178
Here's the factory trouble-shooting guide for Code 34 plus the location of relays & sensors in the engine bay. If the relay isn't bad and cleaning the MAF itself doesn't work, looks like it's a bad MAF to me. (Hope is isn't until you're ready to swap out the TPI system for a carburetor.)
Good luck!
Good luck!
